Garmin VIRB 360 Action Camera
Quicklinx: DWG1WS00 Mfr#: 010-01743-05
VIRB 360 is the first of its kind, capturing a complete sphere of high-resolution video and audio - even photos. It eliminates the lengthy editing process with unrivaled 1-click video stabilization up to 4K resolution at 30 fps and allows you to instantly livestream any adventure.
  • Defining a standard for full-sphere 360 video and audio capture
    If it's worth remembering, it's worth a VIRB 360. This rugged, waterproof camera is true to its name, recording the full 360 degrees - horizontally and vertically. And you can forget about timely post-production work, because VIRB 360 will auto-stitch your 4K footage in camera. If you're looking for higher resolution, you can record video in unstitched 5.7K resolution at 30fps. You can choose between different recording modes such as time lapse, manual and more. Even capture 360-degree photos, burst shots, time lapse and Travelapse photo capture up to 15 megapixels - stitched in camera. Combined with the 4 built-in microphones for 360-degree audio, you and your viewers will be totally immersed in the 360 experience.
  • Captures spherical stabilized 4K video with 1 click
    Take a shaky, hard-to-follow video, and turn it into a smooth and stable masterpiece in 1 click. Regardless of camera movement, the 3 modes of 4K spherical stabilization ensure a smooth video. Stabilize mode smooths quick movements and vibrations without overriding camera orientation. Use lock mode to secure the orientation of the camera in a specified direction. In follow mode, the orientation follows the GPS trajectory.
  • Data overlays with G-Metrix
    Retell your story in greater detail than ever before. Built-in sensors, such as GPS and GLONASS, barometer, accelerometer and more, provide countless customizable G-Metrix data overlay options in 360-degree augmented reality. Just select premade templates of the data points you want, and see your custom data overlay displayed in your video. Other compatible Garmin sensors and devices pair with your VIRB to extend camera control and provide detailed, measurable data tailored to your activity.
  • Control it with your voice
    "OK Garmin, start recording." It's that easy. When you are about to speed down a rugged hillside, chances are you don't want to reach up and press start. Now you can just use a voice command, and the camera will start and stop recording and take photos. Or ask VIRB 360 to "remember that" to tag specific moments in your adventure and quickly find them again later.
  • Make a splash
    This rugged camera is built to endure everything from a whitewater adventure to a child's birthday party. VIRB 360 is waterproof to 10 meters, small and lightweight enough for any adventure, and it features strengthened glass lenses you can easily replace without tools. The camera can shoot more than 1 hour on a single battery charge. The sunlight-readable display shows battery, storage, mode and connectivity status. VIRB 360 can do it all.
Garmin VIRB 360 - action camera
Action camera - 5.7K
Action Camera Type
Mountable
Synchronised Camera Array
Spherical panorama
Memory Card Slot
microSD card
Sensors
Accelerometer, digital compass, altimeter, gyro sensor
Wireless Interface
Wi-Fi, Bluetooth, NFC, ANT/ANT+
Sensor Resolution
2 x 12.0 MP
Effective Sensor Resolution
Photo: 12.0 MP
Max Video Resolution
2880 x 2880
Lens System
2 x wide-angle lens
Focus Adjustment
Focus free
Image Stabiliser
Electronic
Supported Battery
Li-ion rechargeable battery - 1250 mAh (included)
USB 2.0
5.93 cm x 6.98 cm x 3.9 cm
133 g
1-year warranty
Sensor Resolution
2 x
Camcorder Sensor Resolution
12.0 MP
Sensor Qty
2 CMOS
Effective Photo Resolution
12.0 MP
Camcorder Interpolated Photo Resolution
15.0 MP
360° Camera
Widescreen Video Capture
Optical Sensor Type
Dual BSI-CMOS
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
30 fps
ISO (Max)
6400
Image Stabiliser
Electronic
Navigation
GPS/GLONASS receiver
Sensors
Digital Video Format
H.264, RAW
Image Recording Format
JPEG
2880 x 2880
USB 2.0, IEEE 802.11b/g/n, Bluetooth 4.0, NFC (Near Field Communication), ANT/ANT+
Computer Connectivity
Mac, Windows
Connectivity Features
Remote control via mobile devices, remote live view, Live streaming
Exposure & White Balance
Light Sensitivity
ISO 100-6400, ISO auto (100-6400)
Exposure Modes
Programme, automatic
White Balance
Custom, automatic
Exposure Compensation
±2 EV range
Lens System
2 x wide-angle lens - wide angle
Focus Adjustment
Focus free
Max View Angle
360 degree(s)
Additional Features
Continuous Shooting Speed
20 frames per second
Additional Features
Audio recording, multi-picture burst, Time-Lapse recording, One-Touch Audiovisual Recording, voice control
Action Camera Features
Camera Type
Mountable
360° Camera
Panorama Type
Spherical
Optical Sensor Qty
2
G-Metrix augmented reality data overlay
Tripod Mount
Connection Point
1/4" socket
Microphone
Microphone Operation Mode
Surround
Connector Type
USB 2.0
USB cable, tripod adapter, camera cradle, tripod/handgrip
Underwater Use
Underwater Depth
Up to 10 m
Battery Type
Lithium Ion - manufacturer-specific
Details
Battery Life Details
Video recording - 1 hour
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card, microSDHC UHS-I Memory Card, microSDXC UHS-I Card
Memory Card Included
No
Memory Card Max Supported Size
128 GB
Image Storage
JPEG 5640 x 2816 - Stitched 360 , JPEG 3008 x 3000 - Unstitched 360
Video Capture
H.264 - 2880 x 2880 - 30 fps - 120Mbps - Unstitched 360 , H.264 - 2496 x 2496 - 30 fps - 100Mbps - Unstitched 360 , H.264 - 3840 x 2160 - 30 fps - 80Mbps - Stitched 360 , H.264 - 1760 x 1760 - 60 fps - 100Mbps - Unstitched 360 , H.264 - 1920 x 1080 - 120 fps - 50Mbps , H.264 - 1920 x 1080 - 60 fps - 40Mbps
Limited warranty - 1 year
5.93 cm
6.98 cm
3.9 cm
133 g
Weight Details
Camera only: 133 g , Camera with battery: 160 g
