Train more effectively with the premium heart rate monitor. When worn around your chest during an activity, it wirelessly transmits your heart rate to your compatible device for instant feedback on how hard you're working.
The strap is made of a comfortable soft fabric. Adjust the size to your body for secure fit during your activities.
Pair it with your compatible device just once, and it will automatically recognize it each time. Optimized for use in crowded areas like the gym and road races, it won't pick up any signals but your own.
Taking care of it is a snap. The plastic heart-rate module is removable from the strap so you can wash the strap as often as needed.
- Garmin Premium - heart rate sensor
- Product Type
- Heart rate sensor
- Package Content
- Strap, heart rate monitor
- Designed For
- Colorado 300, 400; Dakota 20; Edge 305, 500, 510, 705, 800, 810; eTrex 30; Forerunner 110, 15, 210, 305, 310, 35, 405, 410, 50, 610, 735, 910, FR70; Foretrex 301, 401; GPSMAP 62, 78; MARQ; Montana 600, 650; Oregon 300, 400, 450, 550, 600, 650; RINO 650, 655; VIRB Ultra 30; vívoactive HR
- Product Type
- Heart rate sensor
- Package Content
- Designed For
- Garmin Colorado 300, 400c, 400i, 400t , Garmin Dakota 20, 20 PRO , Garmin Edge 305, 500, 510, 705, 800, 810 , Garmin eTrex 30 , Garmin Forerunner 110, 15, 210, 305, 310XT, 35, 405, 405CX, 410, 50, 610, 735XT, 910XT, FR70 , Garmin Foretrex 301, 401 , Garmin GPSMAP 62s, 62sc, 62st, 62stc, 78s, 78sc , Garmin MARQ , Garmin Montana 600, 600 PRO, 650, 650 PRO, 650t, 650t PRO , Garmin Oregon 300, 300 PRO, 400c, 400i, 400t, 400t PRO, 450, 450 PRO, 450t, 450t PRO, 550, 550 PRO, 550t, 550t PRO, 600, 600t, 650, 650t , Garmin RINO 650, 655t , Garmin VIRB Ultra 30 , Garmin vívoactive HR
