Garmin Forerunner 235 EU GPS Running Watch Black & Frost Blue
Quicklinx: DCCRWS00 Mfr#: 010-03717-49
This GPS running watch with smart features can track distance, pace, time, heart rate and much more. Once you’re done running, it doubles as an activity tracker, counting your steps and calories throughout the day. The Elevate heart rate technology measures heart rate at the wrist 24/7, giving you the possibility to run without a strap. Its colorful gauge identifies your heart rate zone and beats per minute in real time.
  • Customize your watch and your training
    No two runners are the same, and neither are their goals. Set yourself up to reach yours by downloading advanced workouts and training plans to your watch from Garmin Connect. You can even customize your data fields, and download watch faces, widgets and applications all for free at Connect IQ.
  • On and off the road running
    A built-in accelerometer captures distance and pace data when you're running on an indoor track or treadmill, with no need for a separate foot pod accessory. Once you're done running, it doubles as an activity tracker, counting your steps and calories throughout the day. It also reminds you to move after sitting for more than an hour. Forerunner 235 is compatible with GPS and GLONASS satellites to locate your position quickly and precisely whether you're running deep in the woods or near tall buildings.
  • It's simple
    Concise, easy-to-understand charts, graphs, maps and more let you view your activities, track progress toward goals and wirelessly upload and share relevant data directly with the online Garmin Connect network. So, you can compete with friends or family members on weekly step or running challenges - and compare your results in real time, using the LiveTrack feature. You can also use the app's wireless connectivity links to receive current weather conditions, forecasts and smart notifications right on your compatible Garmin device.
Garmin Forerunner 235 sport watch with strap - frost blue
Sport watch
Activity / Sport
Running, cycling
Tracking Data
Distance, time, speed, calories burned, sleep activity, heart rate
Navigation
GPS/GLONASS receiver
Display
Memory-in-Pixel LCD - 1.23" - 215 x 180 pixels - chemically strengthened glass
Case
Round
Band
Strap - silicone
Find phone function, VO2 max, idle alert, HR zones, VIRB control, inactivity alert, Garmin Elevate, LiveTrack, TrueUp, auto pause, auto lap, music playback control, voice instructions
Rechargeable
Frost blue
45 mm x 11.7 mm x 45 mm
42 g
Sport watch
Navigation
Activity / Sport
Running, cycling
Tracking Data
Wearing Style
Watch style
Clock Display
Set Goals
Frost blue
Sensors
Accelerometer, optical heart sensor
Display
Memory-in-Pixel LCD - colour - transflective
Resolution
215 x 180 pixels
Diagonal Size
1.23"
Protection
Chemically strengthened glass
Rechargeable Battery
Run Time Details
GPS mode - up to 11 hour(s) , Smartwatch mode - up to 9 days
Smart Watch Case
Case Shape
Round
Band
Name
Strap
Clasp Type
Buckle
Material
Silicone
45 mm
11.7 mm
45 mm
42 g
Preloaded Software
Calendar, Alarm, Weather, Timer, Find My Phone, Garmion Connect IQ
Vibrating Alert
Protection
Water-resistant
Charging/data cable
Max Depth of Water Resistance
50 m
