This GPS running watch with smart features can track distance, pace, time, heart rate and much more. Once you’re done running, it doubles as an activity tracker, counting your steps and calories throughout the day. The Elevate heart rate technology measures heart rate at the wrist 24/7, giving you the possibility to run without a strap. Its colorful gauge identifies your heart rate zone and beats per minute in real time.
Customize your watch and your training
No two runners are the same, and neither are their goals. Set yourself up to reach yours by downloading advanced workouts and training plans to your watch from Garmin Connect. You can even customize your data fields, and download watch faces, widgets and applications all for free at Connect IQ. -
On and off the road running
A built-in accelerometer captures distance and pace data when you're running on an indoor track or treadmill, with no need for a separate foot pod accessory. Once you're done running, it doubles as an activity tracker, counting your steps and calories throughout the day. It also reminds you to move after sitting for more than an hour. Forerunner 235 is compatible with GPS and GLONASS satellites to locate your position quickly and precisely whether you're running deep in the woods or near tall buildings. -
It's simple
Concise, easy-to-understand charts, graphs, maps and more let you view your activities, track progress toward goals and wirelessly upload and share relevant data directly with the online Garmin Connect network. So, you can compete with friends or family members on weekly step or running challenges - and compare your results in real time, using the LiveTrack feature. You can also use the app's wireless connectivity links to receive current weather conditions, forecasts and smart notifications right on your compatible Garmin device.
- Garmin Forerunner 235 sport watch with strap - frost blue
- Product Type
- Sport watch
- Activity / Sport
- Running, cycling
- Tracking Data
- Distance, time, speed, calories burned, sleep activity, heart rate
- Navigation
- GPS/GLONASS receiver
- Display
- Memory-in-Pixel LCD - 1.23" - 215 x 180 pixels - chemically strengthened glass
- Case
- Round
- Band
- Strap - silicone
- Find phone function, VO2 max, idle alert, HR zones, VIRB control, inactivity alert, Garmin Elevate, LiveTrack, TrueUp, auto pause, auto lap, music playback control, voice instructions
- Battery
- Rechargeable
- Frost blue
- 45 mm x 11.7 mm x 45 mm
- 42 g
- Product Type
- Sport watch
- Navigation
- Activity / Sport
- Running, cycling
- Tracking Data
- Wearing Style
- Watch style
- Clock Display
- Set Goals
- Frost blue
- Sensors
- Accelerometer, optical heart sensor
Display
- Memory-in-Pixel LCD - colour - transflective
- Resolution
- 215 x 180 pixels
- Diagonal Size
- 1.23"
- Protection
- Chemically strengthened glass
- Rechargeable Battery
- Run Time Details
- GPS mode - up to 11 hour(s) , Smartwatch mode - up to 9 days
Smart Watch Case
- Case Shape
- Round
Band
- Name
- Strap
- Clasp Type
- Buckle
- Material
- Silicone
- 45 mm
- 11.7 mm
- 45 mm
- 42 g
- Preloaded Software
- Calendar, Alarm, Weather, Timer, Find My Phone, Garmion Connect IQ
- Vibrating Alert
- Protection
- Water-resistant
- Included Accessories
- Charging/data cable
- Max Depth of Water Resistance
- 50 m
