Garmin Edge 25 Cycling GPS Computer with GLONASS, ANT+ Bluetooth
Quicklinx: DCCXWS00 Mfr#: 010-03709-30
Go the extra mile. Edge 25 captures essential stats from your ride, including time, distance, speed, total ascent and location. When paired with a heart rate strapĀ¹, it also records your heart rate and heart rate zone so you'll know when you hit your target. Heart rate compatibility also provides more accurate information on calories burned during your ride.
  • Stay on course
    Choose from courses ridden by others or create your own on Garmin Connect, the free online community. Once you choose a course, upload it directly to Edge 25 and follow it to your destination. You can even compete against yourself to make it more interesting.
  • Ride faster, ride further
    Edge 25 lets you know how fast and how far you're riding. When paired with ANT+ sensorsĀ², you can also track cadence, as well as indoor speed and distance.
  • Live Tracking
    When paired with Bluetooth, Live Tracking lets friends and family follow your ride in real time. Invite followers using email or social media, which lets them view your live data on Garmin Connect.
  • No data, no problem
    Edge 25 uses GPS/GLONASS satellites to track how far, how fast and where you ride, even under dense tree cover. Unlike a phone, you can use Edge 25 for up to 8 hours without worrying about data or battery drainage.
Garmin Edge 25 - GPS/GLONASS navigator
Display
Monochrome - 128 x 160 pixels
Recommended Use
Cycle
Bluetooth
Heart rate
Tracking Data
Distance
Protection
Waterproof
Mounting bracket, data/charging clip
4 cm x 1.7 cm x 4.2 cm
25 g
Recommended Use
Cycle
Bluetooth
Tracking Data
Distance
Aerial
Built-in
Clock, AutoLap, AutoPause, Virtual Partner, Garmin Connect compatible, Auto Scroll, customisable screen, heart rate
Display
LCD - monochrome
Display Width
2.3 cm
Display Height
2.3 cm
Display Resolution
128 x 160 pixels
Navigation
Waypoints
0
Routes
0
Trip Computer
Trip timer, trip distance
Bluetooth
Rechargeable - Lithium Ion
Protection
Waterproof
Waterproof Standard
IPX7
4 cm
1.7 cm
4.2 cm
25 g
