Product
G.Skill 32GB (4 x 8GB) TridentX DDR3 2400MHz DIMM 240-pin
Quicklinx: 82L4WS00 Mfr#: F3-2400C10Q-32GTX
Type: DDR3 SDRAM
Capacity: 32GB
Connection: DIMM 240-pin
Speed: 2400MHz
Data Integrity: Non-ECC
Hurry, only 1 left in stock!
£227.26 ex VAT
£272.71 inc VAT
Express delivery Order within the next 20 hours for delivery on Thursday
G.Skill TridentX Series - DDR3 - 32 GB : 4 x 8 GB - DIMM 240-pin - 2400 MHz / PC3-19200 - CL10 - 1.65 V - unbuffered - non-ECC
G.Skill TridentX Series - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin - unbuffered
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC3-19200)
Latency Timings
CL10 (10-12-12-31)
Intel Extreme Memory Profiles (XMP), quad channel, TridentX heatspreader with removable top fin, unbuffered
Voltage
1.65 V
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
2.13
Speed
Latency Timings
CL10 (10-12-12-31)
Non-ECC
Voltage
1.65 V
Compatible Slots
4 x memory - DIMM 240-pin
Type: DDR3 SDRAM
Capacity: 32GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
CAS Latency: CL10
Standard: PC3-19200
Brand: G.Skill
Stock Status: Clearance
Price Range Ex VAT: 150 - 300
