The Fujitsu PRIMERGY TX1310 M1 is the ideal first server for small and medium-sized businesses. With plenty of RAM and Intel Xeon processor support it offers more than enough performance for all classic server tasks, such as file, print, web or office applications. The small tower server is build for reliable 24/7 operation and guarantees data safety by high-end features like ECC memory and an onboard RAID controller. Thanks to the screwless chassis and Fujitsu's Easy Rails for hard disks the server is easy to service. Moreover, the PRIMERGY TX1310 M1 is incredibly silent making it an excellent choice for any office environment.
- Fujitsu PRIMERGY TX1310 M1 - tower - Xeon E3-1226V3 3.3 GHz - 8 GB - HDD 2 x 1 TB
- Server - tower
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1226V3 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB L3 Cache
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s); SATA
- Hard Drive
- 2 x HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics P4600
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Software Included
- ServerView
- 17.5 cm x 41.9 cm x 39.5 cm
- 14 kg
- Limited warranty - 1 year - on-site
- Server
- Product Form Factor
- Tower
- 1-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 2
Processor / Chipset
- CPU
- Intel Xeon E3-1226V3
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- L3 Cache - 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 2 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- Business critical
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I217, I210
- Data Link Protocol
- PXE support, Teaming support
- Bays
- 4 (total) / 2 (free) x internal 3.5" x 1/3H , 2 (total) / 1 (free) x external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 2 (total) / 2 (free) x PCIe 3.0 x8 , 1 (total) / 1 (free) x PCIe 2.0 x4 (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 (x4 mode)
- 4 x USB 2.0 (4 rear) , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet)
- FCC Class A certified, CSA, VCCI, C-Tick, GS, CB, ULC, RoHS, WEEE, KC, ETSI 300 019
- Power supply
- Voltage Required
- Power Provided
- 250 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Efficiency
- 85%
Operating System / Software
- Software
- ServerView
- 17.5 cm
- 41.9 cm
- 39.5 cm
- 14 kg
- 10 °C
- 35 °C
- Sound Emission
- 24 dBA
StarTech.com 6 ft 2-in-1 USB KVM Cable | In Stock | £6.96 |
StarTech.com 2 Port Professional USB KVM Switch Kit with Cables | In Stock | £70.16 |
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £94.48 |
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
