Product
Fujitsu SP-1125 A4 Document Scanner
Quicklinx: C38DWS00 Mfr#: PA03708-B011
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 2.0
Compatibility: PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Hurry, only 2 left in stock!
£258.23 ex VAT
£309.87 inc VAT
Evolve from your physical to electronic documents with digital ease with the 25 double sided pages per minute SP-1125 scanner and create one single source reference for all your data by merging these with your digitally born documents. Gain the business advantages of working with more convenient, flexible and secure digital images using simple push button routines, the SP-1125 features a simple operation panel with only 2 buttons (Scan / Stop and Power) as well as software enabled push button management. Bundled with a host of efficient document scanning software for higher productivity: PaperStream IP - Automatically creates the most suitable image data for hassle-free scanning, ABBYY FineReader Sprint - Creates searchable files from your paper documents, allowing you at a later date to find your information easier and Presto! PageManager - Making it easy to scan, share, and organize your documents and files Turn paper into organized digital documents.
  • Compact size scanner for a wide range of users
    The SP Series is compact in size, so it can be used at the desk or at reception where space is limited. Ideal for office branches, SMEs, and any desk-bound users, this series' versatility can best fit users across different platforms and business usages.
  • User friendly
    The simple and easy-to-use design can minimize the scanning procedures and reduce human-error. The SP Series has a simple operation panel with only 2 buttons (Scan/Stop and Power), which can be preset with any software supporting TWAIN and ISIS. The SP Series helps users finish scanning tasks in the shortest time possible.
  • Raise your productivity with efficient image capture
    Evolve from your physical to electronic documents with digital ease with the SP Series. Create one single source reference for all your data by merging these with your digitally born documents. Gain the business advantages of working with more convenient, flexible and secure digital images using simple push button routines, the SP Series feature a simple operation panel with only 2 buttons (Scan / Stop and Power) as well as software enabled push button management. Store, retrieve and manage your documents more productively, efficiently and cost effectively than paper records allow. At the same time actively embrace compliance risk avoidance concerns and increase your customer's satisfaction.
  • Cost effective high performance
    Achieve more in less time. Remove your backlog of documents and transform mixed batches of different thicknesses and sizes including plastic cards into high quality images. The SP Series has been especially designed to provide a simple but efficient paper to digital document capture platform for all types of businesses looking to adopt a more systematic approach to regular document capture Automatic size recognition and blank page removal simplifies scanning operations and pre scan sorting thereby helping to save the inconvenience of fine tuning the document for the OCR process. Fujitsu scanners are renowned for their highly reliable paper handling capabilities and these help remove image capture disruptions to reduce document management overheads.
  • Desktop convenience
    The compact design of the SP Series models takes up minimal space on a busy desktop. The small footprint means these devices are always available and within reach for uninterrupted performance. Trade a small desktop space to reclaim a much larger space taken up by paper records.
  • Document handling and archiving confidence
    Whether dealing with healthcare, legal, financial or other documents that need to comply with long term storage regulations the SP Series helps support the efficient on-ramp into your archives.
  • Faster throughput when it is needed
    The SP Series models through their 50-sheet automatic document feeder (ADF) can process single or double sided pages at the same time.
Fujitsu SP-1125 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CIS
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Max Document Size
210 mm x 3048 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Ubuntu 16.04
29.8 cm x 13.5 cm x 13.3 cm
2.5 kg
Interface Type
USB 2.0
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Scan Element Type
Dual CIS
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Scanner Speed Details
25 ppm - A4 - 200 dpi , 25 ppm - A4 - 300 dpi , 50 ipm - duplex - A4 - 200 dpi , 50 ipm - duplex - A4 - 300 dpi
Scanner Features
De-skewing, Image Emphasis, Dynamic Threshold, Error Diffusion, Ultrasonic multifeed sensor, automatic colour detection, automatic page size detection, blank page skipping, Advanced DTC, Multi-Image Output, RGB Color Dropout, Colour Smoothing
TWAIN, ISIS
Media Handling
Max Document Size
210 mm x 3048 mm
Automatic
50 sheets
USB 2.0 - Type B
RoHS 2011/65/EU
Internal power supply
Power Consumption Operational (Standby)
18 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
1.6 Watt
Software Included
Drivers & Utilities, Presto! PageManager, ABBYY FineReader Sprint, Software Operation Panel, PaperStream IP, Scanner Central Admin Agent, Error Recovery Guide, PaperStream Capture Lite
29.8 cm
13.5 cm
13.3 cm
2.5 kg
5 °C
35 °C
20 - 80% (non-condensing)
C38D Fujitsu Extends Warranty From 1 Year to 3 Year For Office Passport Scanners - Inc Rep and Shipping In Stock £58.19
Interface: USB 2.0
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: 150 - 300
