Evolve from your physical to electronic documents with digital ease with the 25 double sided pages per minute SP-1125 scanner and create one single source reference for all your data by merging these with your digitally born documents. Gain the business advantages of working with more convenient, flexible and secure digital images using simple push button routines, the SP-1125 features a simple operation panel with only 2 buttons (Scan / Stop and Power) as well as software enabled push button management. Bundled with a host of efficient document scanning software for higher productivity: PaperStream IP - Automatically creates the most suitable image data for hassle-free scanning, ABBYY FineReader Sprint - Creates searchable files from your paper documents, allowing you at a later date to find your information easier and Presto! PageManager - Making it easy to scan, share, and organize your documents and files Turn paper into organized digital documents.
Compact size scanner for a wide range of users
The SP Series is compact in size, so it can be used at the desk or at reception where space is limited. Ideal for office branches, SMEs, and any desk-bound users, this series' versatility can best fit users across different platforms and business usages. -
User friendly
The simple and easy-to-use design can minimize the scanning procedures and reduce human-error. The SP Series has a simple operation panel with only 2 buttons (Scan/Stop and Power), which can be preset with any software supporting TWAIN and ISIS. The SP Series helps users finish scanning tasks in the shortest time possible. -
Raise your productivity with efficient image capture
Evolve from your physical to electronic documents with digital ease with the SP Series. Create one single source reference for all your data by merging these with your digitally born documents. Gain the business advantages of working with more convenient, flexible and secure digital images using simple push button routines, the SP Series feature a simple operation panel with only 2 buttons (Scan / Stop and Power) as well as software enabled push button management. Store, retrieve and manage your documents more productively, efficiently and cost effectively than paper records allow. At the same time actively embrace compliance risk avoidance concerns and increase your customer's satisfaction. -
Cost effective high performance
Achieve more in less time. Remove your backlog of documents and transform mixed batches of different thicknesses and sizes including plastic cards into high quality images. The SP Series has been especially designed to provide a simple but efficient paper to digital document capture platform for all types of businesses looking to adopt a more systematic approach to regular document capture Automatic size recognition and blank page removal simplifies scanning operations and pre scan sorting thereby helping to save the inconvenience of fine tuning the document for the OCR process. Fujitsu scanners are renowned for their highly reliable paper handling capabilities and these help remove image capture disruptions to reduce document management overheads. -
Desktop convenience
The compact design of the SP Series models takes up minimal space on a busy desktop. The small footprint means these devices are always available and within reach for uninterrupted performance. Trade a small desktop space to reclaim a much larger space taken up by paper records. -
Document handling and archiving confidence
Whether dealing with healthcare, legal, financial or other documents that need to comply with long term storage regulations the SP Series helps support the efficient on-ramp into your archives. -
Faster throughput when it is needed
The SP Series models through their 50-sheet automatic document feeder (ADF) can process single or double sided pages at the same time.
- Fujitsu SP-1125 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CIS
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Grayscale / Color Depth
- 8-bit (256 colours) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 25 ppm (mono) / 25 ppm (colour)
- Max Document Size
- 210 mm x 3048 mm
- Automatic Duplexing
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04
- 29.8 cm x 13.5 cm x 13.3 cm
- 2.5 kg
- Interface Type
- USB 2.0
- A4 (210 x 297 mm)
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CIS
- Max Document Scan Speed B/W
- 25 ppm
- Max Document Scan Speed Colour
- 25 ppm
- Scanner Speed Details
- 25 ppm - A4 - 200 dpi , 25 ppm - A4 - 300 dpi , 50 ipm - duplex - A4 - 200 dpi , 50 ipm - duplex - A4 - 300 dpi
- Scanner Features
- De-skewing, Image Emphasis, Dynamic Threshold, Error Diffusion, Ultrasonic multifeed sensor, automatic colour detection, automatic page size detection, blank page skipping, Advanced DTC, Multi-Image Output, RGB Color Dropout, Colour Smoothing
- TWAIN, ISIS
Media Handling
- Max Document Size
- 210 mm x 3048 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- RoHS 2011/65/EU
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 18 Watt
- Power Consumption Stand by
- 0.4 Watt
- Power Consumption Sleep
- 1.6 Watt
- Software Included
- Drivers & Utilities, Presto! PageManager, ABBYY FineReader Sprint, Software Operation Panel, PaperStream IP, Scanner Central Admin Agent, Error Recovery Guide, PaperStream Capture Lite
- OS Required
- 29.8 cm
- 13.5 cm
- 13.3 cm
- 2.5 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
