Fujitsu ScanSnap S1300i Deluxe
Quicklinx: 86N6WS00 Mfr#: PA03643-B011
The ScanSnap S1300i Deluxe Bundle comes with Rack2-Filer Smart For Windows users, Rack2-Filer Smart is a feature-rich scanning and content viewing application incorporating an ultra-intuitive bookcase and binder interface that gives users a familiar and enjoyable interaction with their scanned paperwork.
At nearly half the size of a sheet of paper, the ScanSnap S1300i is built for convenience and ease of use, a one button approach allows for scanning of multi-page double-sided documents whether at the desk or on the road. Stack up to 10 pages into the automatic document feeder (ADF) and press the blue button.
ScanSnap S1300i scans both sides of each page at up to 12 pages per minute directly to PDF, searchable PDF, JPEG, or to office applications like Word or Excel . The ScanSnap S1300i automatically recognizes the size of each document, detects and corrects for skew, and shows images in their proper orientation. You can even choose to have blank pages automatically removed.
ScanSnap S1300i comes with an AC Adapter but for added mobile convenience, the ScanSnap S1300i can be powered though the computer's USB ports when an AC power source is not available.
The S1300i supports wireless scanning to iPad, iPhone, Android and Kindle devices for convenient viewing via the mobile app ScanSnap Connect Application.
The S1300i can link to cloud services Dropbox, Evernote, Google Docs, Salesforce CRM and SharePoint Online (for Windows). It also brings some additional cloud syncing functions: Scan to SugarSync and Scan to Salesforce Chatter as well as Scansnap folder for Win OS only where you can scan into your preferred cloud service when no scan interface is available through the import capability.
With the bundled ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents can be automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
The bundled ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
  • Simple, speedy and compact
    The ScanSnap S1300i is a document scanner for the PC or Mac user capable of scanning up to 12 pages per minute/24 images per minute. The 10 page ADF can cope with a mixed variety of single or double sided documents ranging in different size and thickness as well as color or black and white.
  • "Quick menu" facilitates intuitive us
    Users just choose what they want to do from the quick menu, which appears after a document has been scanned. The S1300i quick menu is perfect for everyone, even the complete novice!
  • ScanSnap Receipt
    The ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
  • ScanSnap Sync
    With ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents are automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
Fujitsu ScanSnap S1300i Deluxe - document scanner - portable - USB 2.0
Document scanner - portable
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
12 ppm (mono) / 12 ppm (colour)
Max Document Size
216 mm x 863 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
10 sheets
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Windows 8, Apple OS X 10.8 Mountain Lion, Microsoft Windows XP 32-bit, Apple OS X 10.9 Mavericks, Windows 10
28.4 cm x 9.9 cm x 7.7 cm
1.4 kg
Interface Type
USB 2.0
216 x 863 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
12 ppm
Max Document Scan Speed Colour
12 ppm
Scanner Speed Details
12 ppm - portrait (AC powered) (front) / black & white (back) - A4 - 300 dpi , 24 ipm - duplex - portrait (AC powered) (front) / black & white (back) - A4 - 300 dpi , 4 ppm - portrait (USB bus powered) (front) / black & white (back) - A4 - 200 dpi , 8 ipm - duplex - portrait (USB bus powered) (front) / black & white (back) - A4 - 200 dpi , 9 ppm - portrait (AC powered) (front) / colour (back) - A4 - 200 dpi , 18 ipm - duplex - portrait (AC powered) (front) / colour (back) - A4 - 200 dpi , 3 ppm - portrait (USB bus powered) (front) / colour (back) - A4 - 200 dpi , 6 ipm - duplex - portrait (USB bus powered) (front) / colour (back) - A4 - 200 dpi
Scanner Features
Powered by USB port
Media Handling
Max Document Size
216 mm x 863 mm
Automatic
10 sheets
USB 2.0 - Type B
External power adapter
Power Consumption Operational (Standby)
9 Watt (3.2 Watt)
Software Included
Cardiris, ScanSnap Manager, CardMinder, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Evernote for Windows, Evernote for Mac, ScanSnap Organizer, Fujitsu Rack2-Filer Smart with Magic Desktop
28.4 cm
9.9 cm
7.7 cm
1.4 kg
Limited warranty - replacement - 2 years
5 °C
35 °C
20 - 80%
