Fujitsu ScanSnap S1100i Document Scanner
Quicklinx: B6NPWS00 Mfr#: PA03610-B101
Type: Sheetfed scanner
Form Factor: Portable
Max Paper Size: 216 x 863 mm
Interface: USB 2.0
Compatibility: Mac, PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£110.36 ex VAT
£132.43 inc VAT
The ScanSnap S100i Mobile Scanner for PC and Mac takes document scanning just about anywhere! At just 350g, the ScanSnap S100i is the lightweight companion for front-side document scanning at home or on the road. Whether scanning receipts, contracts, recipes, or plastic cards, ScanSnap takes scanning beyond the desktop and into your world.
Scan at speeds that won't slow you down. The paperwork that you pick-up along the way, can go away quickly. Scan a color, A4 sheet in speeds of 8 pages per minute which is roughly 7.5 seconds per page. Business cards and receipts are even faster, and with Continuous Feed Detection (CFD), just insert the next page, ScanSnap takes the paper in and the effort out.
The S100i supports wireless scanning to iPad, iPhone, Android and Kindle devices for convenient viewing via the mobile app ScanSnap Connect Application.
TheS100i can link to cloud services Dropbox, Evernote, Google Docs, Salesforce CRM and SharePoint Online (for Windows). It also brings some additional cloud syncing functions: Scan to SugarSync and Scan to Salesforce Chatter as well as ScanSnap folder for Win OS only where you can scan into your preferred cloud service when no scan interface is available through the import capability.
With the bundled ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents can be automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
The bundled ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
  • Mobile scanning
    The world's smallest ScanSnap, the ScanSnap S1100i is designed to bring full size document scanning productivity out into the world, wherever you go.
  • Intelligent scan correction
    ScanSnap converts disorganization into order with intelligent features that work behind the scenes to correct images so you don't have to.
  • Compatible with PC or Mac
    The ScanSnap S1100i works on both Mac and PC operating systems, making flexibility and portability a breeze.
  • USB Bus Power for ultimate portability
    The ScanSnap S1100i provides ultimate scanning portability. Whether you're always on the run or need discrete technology for a space conscience lifestyle, the S1100i is the perfect companion.
  • ScanSnap Receipt
    The ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
  • ScanSnap Sync
    With ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents are automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
Ricoh ScanSnap S1100i - sheetfed scanner - portable - USB 2.0
Sheetfed scanner - portable
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Additional Functions
Scan to cloud, scan to smart devices, scan to file
Max Supported Document Size
216 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Size
216 mm x 863 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Manual
Microsoft Windows Vista (32/64 bits) SP2 or later, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11, Apple macOS 10.12
27.3 cm x 4.75 cm x 3.4 cm
350 g
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 863 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Bulb / Light Source Type
RGB LED array
Scanner Speed Details
7.5 sec/scan - A4 - 150 dpi , 7.5 sec/scan - A4 - 200 dpi , 7.5 sec/scan - A4 - 300 dpi , 35 sec/scan - A4 - 600 dpi
Scanner Features
Automatic colour detection, automatic page size detection, Continuous Document Feeding
Media Handling
Max Document Size
216 mm x 863 mm
Manual
USB 2.0
RoHS
ENERGY STAR Certified
Power Consumption Operational (Standby)
2.5 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
1 Watt
Software Included
ScanSnap Manager, CardMinder, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, ScanSnap Organizer, ScanSnap Receipt, Evernote, ScanSnap Sync
27.3 cm
4.75 cm
3.4 cm
350 g
5 °C
35 °C
20 - 80% (non-condensing)
B6NP Fujitsu 5x Carrier Sheets for ScanSnap In Stock £38.09
B6NP Fujitsu Extends Warranty From 1 Year to 3 Year For Mobile Scanners - Inc Replacement and Shipping In Stock £40.29
B6NP Fujitsu F1 Scanner Cleaning Wipes (24 Pack) In Stock £26.99
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Fujitsu
