Your basket is empty
Fujitsu ScanSnap S100i Document Scanner
Quicklinx: B6NPWS00 Mfr#: PA03610-B101
Type: Sheetfed scanner
Form Factor: Portable
Max Paper Size: 216 x 863 mm
Interface: USB 2.0
Compatibility: PC
42 in stock
£114.40 ex VAT
£137.28 inc VAT
The ScanSnap S100i Mobile Scanner for PC and Mac takes document scanning just about anywhere! At just 350g, the ScanSnap S100i is the lightweight companion for front-side document scanning at home or on the road. Whether scanning receipts, contracts, recipes, or plastic cards, ScanSnap takes scanning beyond the desktop and into your world.
Scan at speeds that won't slow you down. The paperwork that you pick-up along the way, can go away quickly. Scan a color, A4 sheet in speeds of 8 pages per minute which is roughly 7.5 seconds per page. Business cards and receipts are even faster, and with Continuous Feed Detection (CFD), just insert the next page, ScanSnap takes the paper in and the effort out.
The S100i supports wireless scanning to iPad, iPhone, Android and Kindle devices for convenient viewing via the mobile app ScanSnap Connect Application.
TheS100i can link to cloud services Dropbox, Evernote, Google Docs, Salesforce CRM and SharePoint Online (for Windows). It also brings some additional cloud syncing functions: Scan to SugarSync and Scan to Salesforce Chatter as well as ScanSnap folder for Win OS only where you can scan into your preferred cloud service when no scan interface is available through the import capability.
With the bundled ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents can be automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
The bundled ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
Fujitsu ScanSnap S1100i - sheetfed scanner
Sheetfed scanner - portable
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Additional Functions
Scan to cloud, scan to smart devices, scan to file
Max Supported Document Size
216 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Size
216 mm x 863 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Manual
Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Apple MacOS X 10.7 - 10.12
27.3 cm x 4.75 cm x 3.4 cm
350 g
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 863 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
Bulb / Light Source Type
RGB LED array
Scanner Speed Details
7.5 sec/scan - A4 - 150 dpi , 7.5 sec/scan - A4 - 200 dpi , 7.5 sec/scan - A4 - 300 dpi , 35 sec/scan - A4 - 600 dpi
Scanner Features
Automatic colour detection, automatic page size detection, Continuous Document Feeding
Media Handling
Max Document Size
216 mm x 863 mm
Manual
USB 2.0
RoHS
Power Consumption Operational (Standby)
2.5 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
1 Watt
Software Included
ScanSnap Manager, CardMinder, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, ScanSnap Organizer, ScanSnap Receipt, Evernote, ScanSnap Sync
27.3 cm
4.75 cm
3.4 cm
350 g
5 °C
35 °C
20 - 80% (non-condensing)
Interface: USB 2.0
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: 100 - 150
