The ScanSnap iX500 provides PC and Mac users an effective way to greatly reduce paper clutter, storage space, and security risk associated with unmanaged paperwork at home or office. For even greater accessibility and usefulness, users can scan wirelessly to a PC or Mac and now iOS or Android mobile devices.
The ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
With ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents are automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
Easily transform paper with the touch of a button
Achieving organization with the ScanSnap iX500 starts with the touch of a single button and ends with a host of productivity features that keep you ahead of the stack. -
Wi-Fi or USB connectivity to a computer
Break free from USB and place ScanSnap just about anywhere in the room with Wi-Fi connectivity to a PC or Mac. -
Scan directly to mobile devices
Quickly bypass the computer altogether and scan a PDF or JPEG file directly to an iOS or Android mobile device or tablet. -
Fast double-sided scanning
Typically, higher quality means lower performance, but the iX500 maintains a speed of up to 25 pages per minute even at 300 dpi in color! -
Built-in "GI" microprocessor
A dual-core CPU-mounted "GI" processor performs the intelligent image enhancement responsible for great looking images with dramatically faster results and more sophisticated connectivity. -
Advanced paper feeding system
Inheriting the superior paper feeding technology of the professional-grade scanners, iX500 achieves exceptional feeding reliability using "Separation Roller" technology to minimize jams and multi-feeds. -
Advanced paper detection
ScanSnap iX500 is equipped with an ultrasonic sensor that can be turned on to help operators avoid losing images. What's more, an interactive interface allows users to easily bypass intentional double-feed such as a taped-receipt on an expense report. -
Accelerated searchable PDF creation
Making PDF files searchable at the point of scanning is a great way to keep them instantly accessible and now you can create a searchable PDF at nearly the same speed as a standard PDF. -
Compatible with PC or Mac
The ScanSnap iX500 works on both Mac and PC operating systems, making flexibility a breeze. -
ScanSnap Receipt
The ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing. -
ScanSnap Sync
- Fujitsu ScanSnap iX500 - document scanner - desktop - USB 3.0, Wi-Fi - with NETGEAR ReadyNAS 312 RN31221D
- Document scanner - desktop
- Interface Type
- USB 3.0, Wi-Fi
- Scanning Sensor Type
- Dual CIS
- Light Source
- RGB LED array
- Additional Functions
- Email, scan to network share
- Max Supported Document Size
- 216 x 863 mm
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 25 ppm (mono) / 25 ppm (colour)
- Max Document Size
- 216 mm x 863 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Windows 8, Apple OS X 10.8 Mountain Lion, Microsoft Windows XP 32-bit, Windows 10
- 29.2 cm x 15.9 cm x 16.8 cm
- 3 kg
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty
- Bundled with
- NETGEAR ReadyNAS 312 RN31221D
- Interface Type
- USB 3.0, Wi-Fi
- 216 x 863 mm
- Bundled with
Scanner
- Input Type
- 600 dpi x 600 dpi
- Dual CIS
- Bulb / Light Source Type
- RGB LED array
- Max Document Scan Speed B/W
- 25 ppm
- Max Document Scan Speed Colour
- 25 ppm
- Scanner Speed Details
- 25 ppm - duplex - portrait - A4 - 150 dpi , 25 ppm - duplex - portrait - A4 - 200 dpi , 25 ppm - duplex - portrait - A4 - 300 dpi , 7 ppm - duplex - portrait - A4 - 600 dpi , 25 ppm - duplex - portrait B&W - A4 - 300 dpi , 25 ppm - duplex - portrait B&W - A4 - 400 dpi , 25 ppm - duplex - portrait B&W - A4 - 600 dpi , 7 ppm - duplex - portrait B&W - A4 - 1200 dpi
- Scanner Features
- One-Button function, Separation Sheet Detection, Ultrasonic multifeed sensor, Wi-Fi connection only for Android / iOS
Media Handling
- Max Document Size
- 216 mm x 863 mm
- Supported Document Size Details
- ADF - up to 216 x 863 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 3.0 - Type B
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 20 Watt
- Software Included
- ScanSnap Manager, CardMinder, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, ScanSnap Organizer, Adobe Acrobat DC (download)
- OS Required
- 29.2 cm
- 15.9 cm
- 16.8 cm
- 3 kg
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
