Brand
Fujitsu ScanSnap iX1500 Document Scanner
Quicklinx: DXZGWS00 Mfr#: PA03770-B001
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 863 mm
Interface: Wi-Fi, USB 3.1 Gen 1
Compatibility: PC, Mac
  • Windows 8.1 (32/64 bits)
£297.15 ex VAT
£356.58 inc VAT
Discover the smarter way to work, using the ScanSnap iX1500. The iX1500’s 4.3-inch LCD touchscreen turns the old way of scanning on its head; instead of scanning a document and choosing what you want to do with it each time, now, after your first simple set-up, you can forget all about it. It also allows multiple users to each personalize the interface with their own set of large, color-coded buttons for the functions they use the most. The all-new ScanSnap Home software enables you to preview, tag, search and retrieve any document easily. ScanSnap Home also uses the text on your scans – such as the shop and company name – to recommend file names by learning and adapting to how you work! ScanSnap Cloud can send them straight to one of up to four different cloud storage locations and is smart enough to recognize which one depending on the document type; photos, receipts, business cards or documents. That means instant sharing with colleagues, friends and family. The reliability of its market leading feed technology and handy receipt guide means the iX1500 makes light work of both large and small items – from A3 documents down to ID cards or receipts. Boot up and be ready to go straight away thanks to the iX1500’s fast start-up – with the touch of just one button, you’ll be scanning within seconds, just open the cover and the ScanSnap iX1500 is ready to go. The ScanSnap iX500 has a speed of 30 double-sided sheets per minute, you’ll be done in no time at all – that means more time to get on with what really matters. The iX500 can be shared out of the box with up to 4 family members or colleagues; even more with additional licenses. Connect the iX1500 directly and instantly to your computer or smart device at home or in your office: from a computer you can utilise either USB, Wi-Fi with access point connect mode, or WiFi direct connect mode and from a smart device you can use either of the two WiFi mode options.
  • Name files faster
    ScanSnap Home uses the text, such as shop and company names, found on your scanned documents to recommend file names. Not only does accuracy of information extraction increase the more you scan, but edits made to file names are learned for later naming suggestions.
  • Find files easily
    ScanSnap Home offers simple yet powerful functions to organize and search all of your document types using folders, tags, and keywords. Now you can find information easier than ever before.
  • ScanSnap's first 4.3 inch touch screen interface
    The iX1500 comes equipped with a user-friendly touch screen, providing an easy to use interface with simple icons and an intuitive user experience.
  • Time saving maintenance notifications
    Receive notifications on the touch screen and from ScanSnap Home whenever Dust Detection spots dust that may result in streaked images. Maintenance notification beforehand enables you to reduce the hassle of time-consuming rescans.
  • Share your ScanSnap for everyone to use
    The iX1500 comes with software for multiple accounts, enabling shared use of a single unit with family members and company colleagues.
  • Create files quickly
    Simply open the document chute and ScanSnap is ready to go. Scan single and double sided documents with ease at a speedy 30 sheets per minute.
  • Versatile paper handling
    With professional grade feeding technology and ultrasonic sensors, ScanSnap handles multi-page documents with ease and can additionally detect and alert the user of multi-feeding errors.
  • Scan large volumes with ease
    Scan large volumes of various types of documents from color photos to double-sided landscape documents with a host of intelligent automatic image processing functions. Together, these features enable you to scan confidently without adjusting any settings.
  • Scan any document
    Scan documents larger than the typical A4 size that need to be folded in half, envelopes and much more with manual scan mode. Documents that are difficult to scan in normal scan mode can now be captured without any issues.
  • Receipts and business cards are no longer a hassle
    Effortlessly scan small documents with the receipt guide. No need to be concerned about fixing receipts and business cards that tend to curl or skew. Designed to be a comfortable fit even when the cover is closed, it dramatically reduces the handling of documents before hitting the scan button.
  • Scan anywhere you want whenever you want
    Connect the iX1500 to your computer or smart device at home and in your office, using existing Wi-Fi environments with access point connect mode. Connecting is also possible in environments without Wi-Fi using direct connect mode, as the scanner itself functions as an access point.
Fujitsu ScanSnap iX1500 - document scanner - desktop - Wi-Fi, USB 3.1 Gen 1
Document scanner - desktop
Interface Type
Scanning Sensor Type
Dual CIS
Light Source
RGB LED array
Max Supported Document Size
216 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
216 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card, receipts
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows 7 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits), Apple macOS 10.12, Apple macOS 10.13, Apple macOS Mojave 10.14
29.2 cm x 16.1 cm x 15.2 cm
3.4 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
216 x 863 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Scanner Speed Details
30 ppm - auto-resolution - A4 , 30 ppm - duplex - auto-resolution - A4 , 30 ppm - black & white - A4 - 300 dpi , 30 ppm - colour - A4 - 150 dpi , 30 ppm - greyscale - A4 - 150 dpi , 30 ppm - duplex - black & white - A4 - 300 dpi , 30 ppm - duplex - colour - A4 - 150 dpi , 30 ppm - duplex - greyscale - A4 - 150 dpi , 30 ppm - black&white better - A4 - 400 dpi , 30 ppm - colour better - A4 - 200 dpi , 30 ppm - greyscale better - A4 - 200 dpi , 30 ppm - duplex - black&white better - A4 - 400 dpi , 30 ppm - duplex - colour better - A4 - 200 dpi , 30 ppm - duplex - greyscale better - A4 - 200 dpi , 30 ppm - black&white best - A4 - 600 dpi , 30 ppm - colour best - A4 - 300 dpi , 30 ppm - greyscale best - A4 - 300 dpi , 30 ppm - duplex - black&white best - A4 - 600 dpi , 30 ppm - duplex - colour best - A4 - 300 dpi , 30 ppm - duplex - greyscale best - A4 - 300 dpi , 8 ppm - black&white excellent - A4 - 1200 dpi , 8 ppm - colour excellent - A4 - 600 dpi , 8 ppm - greyscale excellent - A4 - 600 dpi , 8 ppm - duplex - black&white excellent - A4 - 1200 dpi , 8 ppm - duplex - colour excellent - A4 - 600 dpi , 8 ppm - duplex - greyscale excellent - A4 - 600 dpi
Scanner Features
Page length detection, access point mode, Ultrasonic sensor, 4.3" touch screen TFT display
Media Handling
Max Document Size
216 mm x 863 mm
Supported Document Size Details
ADF - up to 216 x 360 mm , Long document - up to 216 x 863 mm
Automatic
50 sheets
USB 3.1 Gen 1 - Type B
Receipt guide
1 x SuperSpeed USB cable
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
17 Watt
Power Consumption Sleep
1.5 Watt
Software Included
ABBYY FineReader for ScanSnap, ScanSnap Cloud, ScanSnap Home, Kofax Power PDF Standard, ScanSnap Connect, Kofax Power PDF Standard for Mac
System Requirements Details
Windows 7/8.1/10 - Dual-Core Celeron - 1.8 GHz - RAM 2 GB - HD 3.8 GB , MacOS X 10.12/10.13/10.14 - Core i5 - 1.4 GHz - RAM 2 GB - HD 2 GB
29.2 cm
16.1 cm
15.2 cm
3.4 kg
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
DXZG Fujitsu 5x Carrier Sheets for ScanSnap In Stock £35.34
DXZG Fujitsu ScanSnap Bag In Stock £38.29
DXZG Fujitsu Extends Warranty From 1 Year to 3 Year For Desktop Scanners - Inc Replacement and Shipping In Stock £53.71
DXZG Fujitsu F1 Scanner Cleaning Wipes (24 Pack) In Stock £25.04
DXZG Fujitsu Consumable Kit: 3656-200K In Stock £30.07
Interface: Wi-Fi
Interface: USB 3.1 Gen 1
Compatibility: PC
Compatibility: Mac
Brand: Fujitsu
