Fujitsu RX1330M3 LFF Intel Xeon E3-1220v6 8GB 2x1TB 1Yr
Installation required? Contact us today!
Quicklinx: DDW2WS00 Mfr#: VFY:R1333SC080IN
Case Style: Rack-mountable
Processor Type: Xeon
Hard Disk Capacity: 2TB
Processor Speed: 3GHz, 3GHz
Installed Memory: 8GB
  • Xeon
Hurry, only 3 left in stock!
£1,018.38 ex VAT
£1,222.05 inc VAT
The Fujitsu server PRIMERGY RX1330 M3 is a mono-socket rack server, designed to provide a solution for small budgets, yet enabling a rich set of expansions to optimally meet individual demands. Its usage patterns cover file, infrastructure and communication or collaboration applications by delivering optimal memory, PCIe slots and hard drives. Moreover, this 1U server allows for diverse individual configurations with features, such as hot-plug power supply units, redundant fans and RAID controller. By delivering high energy efficiency and operation in higher ambient temperature, the PRIMERGY RX1330 M3 also contributes to very low operational costs.
Fujitsu PRIMERGY RX1330 M3 - rack-mountable - Xeon E3-1220V6 3 GHz - 8 GB - 2 TB
Server - rack-mountable
Height (Rack Units)
1U
Region: Asia Pacific, EMEIA
Server Scalability
1-way
1 x Intel Xeon E3-1220V6 / 3 GHz (3.3 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
Storage Controller
SATA (SATA 6Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
2 x 1 TB (hot-swap) - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
GigE
Power Redundancy
Optional
OS Provided
No operating system
48.26 cm x 57.2 cm x 4.28 cm
Limited warranty - 1 year - on-site
Server
Product Form Factor
Rack-mountable - 1U
Server Scalability
1-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Slots
4 (Total) / 3 (empty)
Unbuffered, single rank
Configuration Features
1 x 8 GB
Hard Drive
HDD - hot-swap
2 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Business critical
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I210
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S4)
Wake on LAN (WoL), PXE support
Bays
4 (total) / 2 (free) x hot-swap 3.5" , 1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 1 (total) / 1 (free) x PCIe 3.0 x4 - low-profile , 2 (total) / 2 (free) x PCIe 3.0 x8 - low-profile
6 x USB 3.0 (2 front, 4 rear) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x management (NIC)
Rack mounting kit
No power cord is included
FCC Class A certified, C-Tick, BSMI, GOST, GS, CB, RoHS, WEEE, cULus, VCCI V-3, KC, cCSAus
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
450 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
OS Provided
No operating system
Software
ServerView
48.26 cm
57.2 cm
4.28 cm
10 °C
35 °C
10 - 85% (non-condensing)
Brand: Fujitsu
Price Range Ex VAT: 1000 - 1500
