The FUJITSU Server PRIMERGY TX300 S8 offers maximum performance, best extendability and highest availability without any compromises. Branches, data centers and SMEs value the performance of the Intel Xeon E5 v2 processor, 1536 GB RAM and GPU card support. 10 extension slots and the redundant power supply enable top availability levels and excellent extendability options. The server is thus ideal for computing-intensive applications, virtualization solutions and databases.
- Fujitsu PRIMERGY TX300 S8 - tower - Xeon E5-2620V2 2.1 GHz - 16 GB - no HDD
- Server - tower - redundant fans
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V2 / 2.1 GHz (, up to 2.6 GHz, (6-core)
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 16 GB (installed) / 1536 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-12800
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s); SATA (SATA 3Gb/s)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD SuperMulti
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 17.7 cm x 77.7 cm x 45.6 cm
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Tower
- 2-way
- Front Accessible Bays Qty
- 3
- Hot-Swap Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon E5-2620V2
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 2.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 16 GB / 1536 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Registered, Memory Mirroring
- Configuration Features
- 2 x 8 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - plug-in card
- Controller Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Storage Controller (2nd)
- 1 x SATA - integrated
- SATA 3Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I350
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Remote Management Controller (iRMC S3)
- PXE support
- Bays
- 4 (total) / 4 (free) x hot-swap 3.5" , 3 (total) / 2 (free) x external 5.25"
- Slots
- 2 (total) / 1 (free) x CPU , 24 (total) / 22 (free) x memory , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-height (x4 mode) , 4 (total) / 3 (free) x PCIe 3.0 x8 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x8 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-height (x4 mode)
- 10 x USB 2.0 (2 front, 4 rear, 2 internal) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
- Redundant fans
- FCC Class A certified, VCCI, C-Tick, GS, CB, RoHS, WEEE, cCSAus
- Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Installed Qty
- 2
- Max Supported Qty
- 4
- Voltage Required
- Power Provided
- 800 Watt
- 17.7 cm
- 77.7 cm
- 45.6 cm
- 10 °C
- 35 °C
- 10 - 85% (non-condensing)
- Sound Emission
- 33 dBA
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
