Product
Brand
Fujitsu Primergy TX2560 M1 Intel Xeon E5-2620v3 2x8GB
Quicklinx: B7MYWS00 Mfr#: VFY:T2561SC010IN
  • Xeon
The FUJITSU Server PRIMERGY TX2560 M1 offers maximum performance, best expandability and highest availability without any compromises. Branches, data centers and SMEs value the performance of Intel Xeon processors. Up to 10 extension slots and the redundant power supply enable top availability levels and excellent expandability options. The server is thus ideal for performance hungry applications, virtualization solutions and storage demanding scenarios.
Fujitsu PRIMERGY TX2560 M1 - tower - Xeon E5-2620V3 2.4 GHz - 8 GB - 0 GB
Server - tower
Height (Rack Units)
4U
Server Scalability
2-way
1 x Intel Xeon E5-2620V3 / 2.4 GHz (3.2 GHz) (6-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
8 GB (installed) / 768 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8; SATA
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD±RW (±R DL) / DVD-RAM
GigE
Power Redundancy
Optional
17.7 cm x 77.7 cm x 45.6 cm
Limited warranty - 3 years - on-site
Server
Product Form Factor
Tower - 4U
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C612
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 768 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
DIMM 288-pin
Registered, single rank
Configuration Features
1 x 8 GB
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Storage Controller (2nd)
1 x SATA
Channel Qty
2
Optical Storage
DVD±RW (±R DL) / DVD-RAM - SATA
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S4)
PXE support
Bays
8 (total) / 8 (free) x hot-swap 3.5" , 3 (total) / 2 (free) x external 5.25"
Slots
2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin , 5 (total) / 4 (free) x PCIe 3.0 x8 - full-height , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-height
4 x USB 2.0 (2 rear, 2 internal) , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x VGA , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x management - RJ-45
Cool-safe Advanced Thermal Design
FCC Class A certified, C-Tick, GS, CB, RoHS, WEEE, cCSAus, VCCI Class A, JIS C 61000-3-2
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Max Supported Qty
2
Nominal Voltage
Power Provided
450 Watt
Efficiency
94%
17.7 cm
77.7 cm
45.6 cm
5 °C
10 - 85% (non-condensing)
Sound Emission
24 dB
