The FUJITSU Server PRIMERGY TX2560 M1 offers maximum performance, best expandability and highest availability without any compromises. Branches, data centers and SMEs value the performance of Intel Xeon processors. Up to 10 extension slots and the redundant power supply enable top availability levels and excellent expandability options. The server is thus ideal for performance hungry applications, virtualization solutions and storage demanding scenarios.
- Fujitsu PRIMERGY TX2560 M1 - tower - Xeon E5-2620V3 2.4 GHz - 8 GB - no HDD
- Server - tower - Cool-safe Advanced Thermal Design
- Height (Rack Units)
- 4U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V3 / 2.4 GHz (, up to 3.2 GHz, (6-core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 768 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8; SATA
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD SuperMulti
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 17.7 cm x 77.7 cm x 45.6 cm
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Tower - 4U
- 2-way
- Front Accessible Bays Qty
- 3
- Hot-Swap Bays Qty
- 8
Processor / Chipset
- CPU
- Intel Xeon E5-2620V3
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 768 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Registered, single rank
- Configuration Features
- 1 x 8 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Storage Controller (2nd)
- 1 x SATA
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Remote Management Controller (iRMC S4)
- PXE support
- Bays
- 8 (total) / 8 (free) x hot-swap 3.5" , 3 (total) / 2 (free) x external 5.25"
- Slots
- 2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin , 5 (total) / 4 (free) x PCIe 3.0 x8 - full-height , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-height
- 4 x USB 2.0 (2 rear, 2 internal) , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x VGA , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x management - RJ-45
- FCC Class A certified, C-Tick, GS, CB, RoHS, WEEE, cCSAus, VCCI Class A, JIS C 61000-3-2
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 450 Watt
- Efficiency
- 94%
- 17.7 cm
- 77.7 cm
- 45.6 cm
- 5 °C
- 40 °C
- 10 - 85% (non-condensing)
- Sound Emission
- 24 dB
