Fujitsu PRIMERGY TX2540 M1 Intel Xeon E5-2420v2 2x8GB No HDD
Quicklinx: 9J4SWS00 Mfr#: VFY:T2541SX110GB
  • Xeon
The Fujitsu PRIMERGY TX2540 M1 is the perfect tower server for SMEs as well as branch offices. It supports up to two processors and combines affordable performance with balanced expandability.
Fujitsu PRIMERGY TX2540 M1 - tower - Xeon E5-2420V2 2.2 GHz - 16 GB
Server - tower
Height (Rack Units)
4U
Region: United Kingdom
Server Scalability
2-way
1 x Intel Xeon E5-2420V2 / 2.2 GHz (2.7 GHz) (6-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
16 GB (installed) / 192 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-12800
Storage Controller
RAID (SATA 6Gb/s / SAS 6Gb/s); SATA (SATA 3Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD SuperMulti
GigE
Power Redundancy
Optional
17.7 cm x 65.1 cm x 45.6 cm
Limited warranty - 3 years - on-site
Server
Product Form Factor
Tower - 4U
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Max Turbo Speed
2.7 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C602
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
16 GB / 192 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Registered
Configuration Features
2 x 8 GB
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card
Controller Interface Type
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
1 GB
Storage Controller (2nd)
1 x SATA - integrated
SATA 3Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I210
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC)
PXE support
Bays
4 (total) / 4 (free) x hot-swap 3.5" , 3 (total) / 2 (free) x external 5.25"
Slots
2 (total) / 1 (free) x CPU , 12 (total) / 10 (free) x memory , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-height (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-height (2 processors must be installed) , 1 (total) / 0 (free) x PCIe 2.0 x8 - full-height (x4 mode) , 1 (total) / 1 (free) x PCI
9 x USB 2.0 , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
FCC Class A certified, TUV GS, C-Tick, BSMI, CB, RoHS, WEEE, cULus, cCSAus, VCCI Class A, JIS C 61000-3-2
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
450 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
17.7 cm
65.1 cm
45.6 cm
10 °C
35 °C
10 - 85% (non-condensing)
9J4S C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
9J4S C2G 5m USB 2.0 A/B Cable - Black In Stock £5.14
9J4S C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.94
9J4S C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.13
9J4S C2G USB Superbooster Extender Kit In Stock £38.72
9J4S C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.94
9J4S C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
