Fujitsu PRIMERGY TX2540 M1 Intel Xeon E5-2407v2 8GB No HDD
Installation required? Contact us today!
Quicklinx: 9J4RWS00 Mfr#: VFY:T2541SC050GB
  • Xeon
The Fujitsu PRIMERGY TX2540 M1 is the perfect tower server for SMEs as well as branch offices. It supports up to two processors and combines affordable performance with balanced expandability.
Fujitsu PRIMERGY TX2540 M1 - tower - Xeon E5-2407V2 2.4 GHz - 8 GB
Server - tower
Height (Rack Units)
4U
Region: United Kingdom
Server Scalability
2-way
1 x Intel Xeon E5-2407V2 / 2.4 GHz (Quad-Core)
Cache Memory
10 MB
Cache Per Processor
10 MB
RAM
8 GB (installed) / 192 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-12800
Storage Controller
SATA (SATA 3Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD SuperMulti
GigE
17.7 cm x 65.1 cm x 45.6 cm
Limited warranty - 3 years - on-site
Server
Product Form Factor
Tower - 4U
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C602
Cache Memory
Installed Size
10 MB
Cache Per Processor
10 MB
RAM
Installed Size
8 GB / 192 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Registered
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I210
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC)
PXE support
Bays
4 (total) / 4 (free) x hot-swap 3.5" , 3 (total) / 2 (free) x external 5.25"
Slots
2 (total) / 1 (free) x CPU , 12 memory , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-height (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-height (x4 mode) , 1 (total) / 1 (free) x PCI
9 x USB 2.0 , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
FCC Class A certified, TUV GS, C-Tick, BSMI, CB, RoHS, WEEE, cULus, cCSAus, VCCI Class A, JIS C 61000-3-2
Power supply
Nominal Voltage
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Gold
Efficiency
90%
17.7 cm
65.1 cm
45.6 cm
10 °C
35 °C
10 - 85% (non-condensing)
9J4R C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
9J4R C2G 5m USB 2.0 A/B Cable - Black In Stock £5.15
9J4R C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.16
9J4R C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.24
9J4R C2G USB Superbooster Extender Kit In Stock £38.96
9J4R C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £24.09
9J4R C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
