Fujitsu Server Primergy systems provide the most powerful and flexible data center solutions for companies of all sizes, across all industries and for any type of workload. This includes expandable Primergy tower servers for remote and branch offices, versatile rack-mount servers, compact and scalable blade systems, as well as density-optimized scale-out servers. They convince by business proven quality with a wide range of innovations, highest efficiency cutting operational cost and complexity, and provide more agility in daily operations in order to turn IT faster into a business advantage.
- Fujitsu PRIMERGY RX2530 M1 - rack-mountable - Xeon E5-2620V3 2.4 GHz - 8 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V3 / 2.4 GHz (, up to 3.2 GHz, (6-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 768 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD SuperMulti
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- Software Included
- ServerView
- 48.3 cm x 43.5 cm x 7.24 cm
- Limited warranty - 3 years
- Server
- Product Form Factor
- Rack-mountable - 1U
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon E5-2620V3
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 768 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered
- Configuration Features
- 1 x 8 GB
- RAM Supported
- 768 GB registered - ECC , 1536 GB Load-Reduced - ECC
Hard Drive
- No HDD
Storage Controller
- RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.1
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Remote Management Controller (iRMC S4)
- PXE support
- Bays
- 4 (total) / 4 (free) x hot-swap 2.5" , 1 (total) / 0 (free) x external 5.25"
- Slots
- 2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin , 2 (total) / 2 (free) x PCIe 3.0 x8 - low-profile , 2 (total) / 2 (free) x PCIe 3.0 x16 - low-profile
- 1 x USB 2.0 (1 rear) , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 2 x VGA , 1 x serial , 1 x management , 2 x LAN (Gigabit Ethernet)
- FCC Class A certified, C-Tick, ICES-003, CB, CCC, RoHS, WEEE, KC, cCSAus, NMB-3 Class A, VCCI V-3/2013.04 Class A
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 450 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
Operating System / Software
- Software
- ServerView
- 48.3 cm
- 43.5 cm
- 7.24 cm
- 5 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
