Fujitsu Primergy RX2520 M1 Intel Xeon E5-2420v2 8GB No HDD
Quicklinx: 9J4WWS00 Mfr#: VFY:R2521SX130GB
  • Xeon
The Fujitsu PRIMERGY RX2520 M1 is an efficient and scalable platform featuring the Intel Xeon processor. Its compact PRIMERGY 2U modular chassis provides up to twelve 3.5-inch or sixteen 2.5-inch storage drives.
Fujitsu PRIMERGY RX2520 M1 - rack-mountable - Xeon E5-2420V2 2.2 GHz - 8 GB
Server - rack-mountable
Height (Rack Units)
2U
Region: United Kingdom
Server Scalability
2-way
1 x Intel Xeon E5-2420V2 / 2.2 GHz (2.7 GHz) (6-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
8 GB (installed) / 192 GB (max) DDR3 SDRAM - Advanced ECC - PC3-12800
Storage Controller
RAID (SATA 6Gb/s / SAS 6Gb/s); SATA (SATA 3Gb/s)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD SuperMulti
GigE
Power Redundancy
48.26 cm x 77 cm x 8.69 cm
Limited warranty - 3 years - on-site
Server
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Front Accessible Bays Qty
4
Processor / Chipset
CPU
Max Turbo Speed
2.7 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C600
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 192 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Registered
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card
Controller Interface Type
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
1 GB
Storage Controller (2nd)
1 x SATA - integrated
SATA 3Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
Intel I210
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S4)
PXE support
Bays
Hot-swap 2.5" , 2 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 5.25" , 1 (total) / 1 (free) x external 3.5"
Slots
2 (total) / 1 (free) x CPU , 12 memory , 6 (total) / 5 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode)
9 x USB 2.0 , 1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x management (NIC)
FCC Class A certified, VCCI, C-Tick, GS, CB, RoHS, WEEE, cCSAus
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Nominal Voltage
Power Provided
450 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
48.26 cm
77 cm
8.69 cm
5 °C
10 - 85% (non-condensing)
Sound Emission
34 dBA
9J4W C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
9J4W C2G 5m USB 2.0 A/B Cable - Black In Stock £5.01
9J4W C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.49
9J4W C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.39
