The Fujitsu PRIMERGY RX2520 M1 is an efficient and scalable platform featuring the Intel Xeon processor. Its compact PRIMERGY 2U modular chassis provides up to twelve 3.5-inch or sixteen 2.5-inch storage drives.
- Fujitsu PRIMERGY RX2520 M1 - rack-mountable - Xeon E5-2420V2 2.2 GHz - 8 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Localisation
- Region: United Kingdom
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2420V2 / 2.2 GHz (, up to 2.7 GHz, (6-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 192 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-12800
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s); SATA (SATA 3Gb/s)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD SuperMulti
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 48.26 cm x 77 cm x 8.69 cm
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Rack-mountable - 2U
- 2-way
- Front Accessible Bays Qty
- 4
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2420V2
- Clock Speed
- 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 192 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Registered
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - plug-in card
- Controller Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 1 GB
Storage Controller (2nd)
- 1 x SATA - integrated
- SATA 3Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- Intel I210
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Remote Management Controller (iRMC S4)
- PXE support
- Bays
- Hot-swap 2.5" , 2 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 5.25" , 1 (total) / 1 (free) x external 3.5"
- Slots
- 2 (total) / 1 (free) x CPU , 12 memory , 6 (total) / 5 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode)
- 9 x USB 2.0 , 1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x management (NIC)
- FCC Class A certified, VCCI, C-Tick, GS, CB, RoHS, WEEE, cCSAus
- Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 450 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
- 48.26 cm
- 77 cm
- 8.69 cm
- 5 °C
- 40 °C
- 10 - 85% (non-condensing)
- Sound Emission
- 34 dBA
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
