Product
Fujitsu Primergy RX200 Intel Xeon E5-2620v2 8GB
Quicklinx: 9B0ZWS00 Mfr#: VFY:R2008SX110GB
  • Xeon
The Fujitsu Server PRIMERGY RX200 S8 is a rack server that provides high performance of the Intel Xeon E5 product family, expandability up to 1536 GB of memory and up to 96% energy efficiency - all in 1U space saving housing. Thus, the PRIMERGY RX200 S8 is ideal for virtualization and cloud, small databases as well as for high performance computing.
Fujitsu PRIMERGY RX200 S8 - rack-mountable - Xeon E5-2620V2 2.1 GHz - 8 GB
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon E5-2620V2 / 2.1 GHz (2.6 GHz) (6-core)
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
8 GB (installed) / 1536 GB (max) - DDR3 SDRAM - Advanced ECC
Storage Controller
SATA (SATA 3Gb/s); SATA
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD SuperMulti
GigE
Power Redundancy
Optional
48.2 cm x 76.2 cm x 4.3 cm
Limited warranty - 3 years - on-site
Server
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Max Turbo Speed
2.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C600
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 1536 GB (max)
Registered, Memory Mirroring
Configuration Features
1 x 8 GB
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
Channel Qty
1
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I350
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S3)
PXE support
Bays
4 (total) / 4 (free) x hot-swap 2.5" , 1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line)
Slots
2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x memory , 3 (total) / 3 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
6 x USB 2.0 (2 front, 3 rear) , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
Redundant fans
FCC Class A certified, GS, CB, ICES-003 Class A, RoHS, WEEE, cULus, cCSAus, VCCI Class A
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
450 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
48.2 cm
76.2 cm
4.3 cm
5 °C
10 - 85% (non-condensing)
Sound Emission
34 dBA
9B0Z C2G 2m USB 2.0 A/B Cable - Black In Stock £3.87
9B0Z C2G 5m USB 2.0 A/B Cable - Black In Stock £4.51
9B0Z C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.76
9B0Z C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
9B0Z C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.73
9B0Z C2G USB 2.0 To Fast Ethernet Adapter In Stock £21.28
9B0Z C2G USB Superbooster Extender Kit In Stock £37.81
9B0Z C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.38
9B0Z C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
