Fujitsu PRIMERGY RX1330 M1 - rack-mountable - Xeon E3-1220V3 3.1 GHz - 8 GB - HDD 2 x 1 TB
Quicklinx: 9QBRWS00 Mfr#: VFY:R1331SC030IN
  • Xeon
The Fujistsu Server PRIMERGY RX1330 M1 is a mono-socket rack server designed to provide a solution for small budgets, yet enabling a rich set of optional expansions to best meet individual demands. Its usage patterns cover file, infrastructure and communication applications by delivering up to 32 GB RAM, up to 3 PCIe slots and up to 10 hard disk drives. Moreover, this 1U server allows for diverse individual configurations with optional features, such as hot-plug power supply units, redundant fans, RAID controller and support for pGFX integrated server graphics for fast media processing. By delivering high energy efficiency and operation in higher ambient temperature thanks to optional Cool-safe Advanced thermal Design, the PRIMERGY RX1330 M1 also contributes to very low operational costs.
Server - rack-mountable - redundant fans
Height (Rack Units)
1U
Server Scalability
1-way
1 x Intel Xeon E3-1220V3 / 3.1 GHz (, up to 3.5 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
2 x HDD 1 TB (hot-swap) - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
GigE
Power Redundancy
Optional
OS Provided
No operating system
Software Included
ServerView
48.26 cm x 57.2 cm x 4.28 cm
13 kg
Limited warranty - 1 year - on-site
Server
Product Form Factor
Rack-mountable - 1U
Server Scalability
1-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Clock Speed
3.1 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1150 Socket
Chipset Type
Intel C226
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Unbuffered, dual channel memory architecture, dual rank
Configuration Features
1 x 8 GB
Hard Drive
HDD - hot-swap
2 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Business critical
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Interface (Bus) Type
iSCSI
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I210
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S4)
Wake on LAN (WoL), PXE support
Bays
4 (total) / 2 (free) x hot-swap 3.5" , 1 (total) / 0 (free) x external 5.25" Ultra Slim
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 2 (total) / 2 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode)
4 x USB 2.0 (2 rear, 2 internal) , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
Rack mounting kit
Redundant fans
FCC Class A certified, VCCI, C-Tick, BSMI, GOST, GS, CB, CCC, RoHS, WEEE, cULus, KC, cCSAus
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
450 Watt
Efficiency
94%
Operating System / Software
OS Provided
No operating system
Software
ServerView
48.26 cm
57.2 cm
4.28 cm
13 kg
5 °C
10 - 85% (non-condensing)
Sound Emission
24 dBA
9QBR C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
