The Fujistsu Server PRIMERGY RX1330 M1 is a mono-socket rack server designed to provide a solution for small budgets, yet enabling a rich set of optional expansions to best meet individual demands. Its usage patterns cover file, infrastructure and communication applications by delivering up to 32 GB RAM, up to 3 PCIe slots and up to 10 hard disk drives. Moreover, this 1U server allows for diverse individual configurations with optional features, such as hot-plug power supply units, redundant fans, RAID controller and support for pGFX integrated server graphics for fast media processing. By delivering high energy efficiency and operation in higher ambient temperature thanks to optional Cool-safe Advanced thermal Design, the PRIMERGY RX1330 M1 also contributes to very low operational costs.
- Fujitsu PRIMERGY RX1330 M1 - rack-mountable - Xeon E3-1220V3 3.1 GHz - 8 GB - HDD 2 x 1 TB
- Server - rack-mountable - redundant fans
- Height (Rack Units)
- 1U
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1220V3 / 3.1 GHz (, up to 3.5 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- 2 x HDD 1 TB (hot-swap) - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Software Included
- ServerView
- 48.26 cm x 57.2 cm x 4.28 cm
- 13 kg
- Limited warranty - 1 year - on-site
- Server
- Product Form Factor
- Rack-mountable - 1U
- 1-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon E3-1220V3
- Clock Speed
- 3.1 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Unbuffered, dual channel memory architecture, dual rank
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- Business critical
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA
- Integrated
- Interface (Bus) Type
- iSCSI
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I210
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Remote Management Controller (iRMC S4)
- Wake on LAN (WoL), PXE support
- Bays
- 4 (total) / 2 (free) x hot-swap 3.5" , 1 (total) / 0 (free) x external 5.25" Ultra Slim
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 2 (total) / 2 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode)
- 4 x USB 2.0 (2 rear, 2 internal) , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
- Included Accessories
- Rack mounting kit
- Redundant fans
- FCC Class A certified, VCCI, C-Tick, BSMI, GOST, GS, CB, CCC, RoHS, WEEE, cULus, KC, cCSAus
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 450 Watt
- Efficiency
- 94%
Operating System / Software
- OS Provided
- Software
- ServerView
- 48.26 cm
- 57.2 cm
- 4.28 cm
- 13 kg
- 5 °C
- 40 °C
- 10 - 85% (non-condensing)
- Sound Emission
- 24 dBA
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
