Fujitsu Primergy Intel Xeon E52620v4 16GB LFF Rack Tower Server
Quicklinx: CYGXWS00 Mfr#: VFY:R2512SC030IN
Case Style: Rack-mountable
Processor Type: Xeon
Hard Disk Capacity: 0GB
Processor Speed: 2.1GHz
Installed Memory: 16GB
  • Xeon
£1,344.09 ex VAT
£1,612.90 inc VAT
Based on proven PRIMERGY technology, the FUJITSU Server PRIMERGY RX2510 M2 is a rack server that balances optimal dual-socket performance, easy manageability and outstanding energy efficiency with cost-efficient operation. The 1U housing not only saves in terms of rack space, but also saves on your initial investment costs. Therefore, the RX2510 M2 is ideally suited for large scale-out scenarios as can be seen in the landscape of different kinds of service providers and hosters. Your aim, to deliver the optimal service experience for your customers lead to a system design that not only continuously meets accessibility demands driven by your business, but also the variability to define the systems as required. Optimized for web hosting, managed CRM services, shared, managed or private cloud environments, or other XaaS solutions, the PRIMERGY RX2510 M2 is the right choice.
Fujitsu PRIMERGY RX2510 M2 - rack-mountable - Xeon E5-2620V4 2.1 GHz - 16 GB
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon E5-2620V4 / 2.1 GHz (3 GHz) (8-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
20 MB
Cache Per Processor
20 MB
RAM
16 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
GigE
Power Redundancy
Optional
48.3 cm x 77.07 cm x 4.3 cm
Limited warranty - 3 years - on-site
Server
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
20 MB
Cache Per Processor
20 MB
RAM
Installed Size
16 GB / 384 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
12 (Total) / 11 (empty)
Registered, dual rank, slots 7 - 12 are available in two-processor configuration only
Configuration Features
1 x 16 GB
Hard Drive
No HDD
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I350-T2
Remote Management Protocol
SNMP 2, IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S4)
PXE support
Bays
4 (total) / 4 (free) x hot-swap 3.5"
Slots
2 (total) / 1 (free) x CPU , 12 (total) / 11 (free) x DIMM 288-pin , 2 PCIe 3.0 x8 - low-profile , 1 PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (2 processors must be installed)
1 x USB 2.0 (1 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA (1 rear) , 1 x serial (1 rear) , 1 x management (NIC) - RJ-45 , 2 x LAN (Gigabit Ethernet) - RJ-45
Rack mounting kit, cable arm, power supply dummy
FCC Class A certified, CB, ICES-003 Class A, RoHS, WEEE, VCCI V-3, cCSAus, JIS C 61000-3-2, NMB-3 Class A, KN32, KN35
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
450 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
Software
ServerView
48.3 cm
77.07 cm
4.3 cm
5 °C
10 - 85% (non-condensing)
Sound Emission
31 dBA
Brand: Fujitsu
Price Range Ex VAT: 1000 - 1500
