Fujitsu Primergy Intel Xeon E52609v4 8GB SFF Tower Server
Installation required? Contact us today!
Quicklinx: CYGSWS00 Mfr#: VFY:T2562SC030IN
  • Xeon
The FUJITSU Server PRIMERGY TX2560 offers maximum performance, best expandability and highest availability without any compromises. Branches, data centers and SMEs value the performance of Intel Xeon processors. Up to 10 extension slots and the redundant power supply enable top availability levels and excellent expandability options. The server is thus ideal for performance hungry applications, virtualization solutions and storage demanding scenarios.
Fujitsu PRIMERGY TX2560 M2 - tower - Xeon E5-2609V4 1.7 GHz - 8 GB
Server - tower
Height (Rack Units)
4U
Region: India, Asia Pacific, EMEA
Server Scalability
2-way
1 x Intel Xeon E5-2609V4 / 1.7 GHz (8-core)
Processor Socket
LGA2011-v3 Socket
Cache Memory
20 MB
Cache Per Processor
20 MB
RAM
8 GB (installed) / 1536 GB (max) - DDR4 SDRAM - ECC - PC4-19200
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8; SATA
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD SuperMulti
GigE
Power Redundancy
Optional
17.7 cm x 77.7 cm x 45.6 cm
Limited warranty - 3 years - on-site
Server
Product Form Factor
Tower - 4U
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
20 MB
Cache Per Processor
20 MB
RAM
Installed Size
8 GB / 1536 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1866 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, single rank, Memory Mirroring, Memory Sparing, quad channel memory architecture, slots 13 - 24 are available in two-processor configuration only
Configuration Features
1 x 8 GB
RAM Supported
PC4-19200 - 1536 GB Load-Reduced - ECC , PC4-19200 - 768 GB registered - ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Storage Controller (2nd)
1 x SATA
Channel Qty
2
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S4)
PXE support
Bays
8 (total) / 8 (free) x hot-swap 2.5" , 3 (total) / 2 (free) x external 5.25"
Slots
2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin , 5 (total) / 4 (free) x PCIe 3.0 x8 - full-height , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-height
4 x USB 2.0 (2 rear, 2 internal) , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x management - RJ-45
Power supply dummy
FCC Class A certified, C-Tick, GS, CB, RoHS, WEEE, cCSAus, VCCI Class A, JIS C 61000-3-2, KN32, KN35
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
450 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
Software
ServerView
17.7 cm
77.7 cm
45.6 cm
5 °C
45 °C
10 - 85% (non-condensing)
