The FUJITSU Server PRIMERGY TX2560 offers maximum performance, best expandability and highest availability without any compromises. Branches, data centers and SMEs value the performance of Intel Xeon processors. Up to 10 extension slots and the redundant power supply enable top availability levels and excellent expandability options. The server is thus ideal for performance hungry applications, virtualization solutions and storage demanding scenarios.
- Fujitsu PRIMERGY TX2560 M2 - tower - Xeon E5-2609V4 1.7 GHz - 8 GB - no HDD
- Server - tower
- Height (Rack Units)
- 4U
- Localisation
- Region: India, Asia Pacific, EMEA
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2609V4 / 1.7 GHz (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Cache Memory
- 20 MB
- Cache Per Processor
- 20 MB
- RAM
- 8 GB (installed) / 1536 GB (max) - DDR4 SDRAM - ECC - PC4-19200
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8; SATA
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD SuperMulti
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- Software Included
- ServerView
- 17.7 cm x 77.7 cm x 45.6 cm
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Tower - 4U
- 2-way
- Front Accessible Bays Qty
- 3
- Hot-Swap Bays Qty
- 8
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2609V4
- Clock Speed
- 1.7 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 20 MB
- 20 MB
RAM
- Installed Size
- 8 GB / 1536 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, single rank, Memory Mirroring, Memory Sparing, quad channel memory architecture, slots 13 - 24 are available in two-processor configuration only
- Configuration Features
- 1 x 8 GB
- RAM Supported
- PC4-19200 - 1536 GB Load-Reduced - ECC , PC4-19200 - 768 GB registered - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 2 GB
Storage Controller (2nd)
- 1 x SATA
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Remote Management Controller (iRMC S4)
- PXE support
- Bays
- 8 (total) / 8 (free) x hot-swap 2.5" , 3 (total) / 2 (free) x external 5.25"
- Slots
- 2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin , 5 (total) / 4 (free) x PCIe 3.0 x8 - full-height , 3 (total) / 3 (free) x PCIe 3.0 x16 - full-height
- 4 x USB 2.0 (2 rear, 2 internal) , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x management - RJ-45
- Included Accessories
- Power supply dummy
- FCC Class A certified, C-Tick, GS, CB, RoHS, WEEE, cCSAus, VCCI Class A, JIS C 61000-3-2, KN32, KN35
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 450 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
Operating System / Software
- Software
- ServerView
- 17.7 cm
- 77.7 cm
- 45.6 cm
- 5 °C
- 45 °C
- 10 - 85% (non-condensing)
