Flexibility, expandability, desktop replacement and investment protection are just a few of the many benefits of Fujitsu's docking devices. Port replicators are the perfect docking solution for your notebooks, tablets and mobile workstations. In the office or at home it takes just a second to attach your device to the port replicator and get connected to peripherals such as an external display, keyboard and mouse. Your workplace is simplified and tidy while you work with your Fujitsu device.
For CELSIUS Mobile H730, H730 Optimized for Adobe; LIFEBOOK E544, E734, E744, E754, T725, U745
- Fujitsu - port replicator - VGA, DVI
- Product Type
- Port replicator
- Video Interfaces
- VGA, DVI
- 540 g
- Power
- Power adapter
- Designed For
- CELSIUS Mobile H730, H730 Optimized for Adobe; LIFEBOOK E544, E734, E744, E754, T725, U745
- Product Type
- Port replicator
- 540 g
- 1 x audio - line-In , 1 x audio - line-out , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - Ethernet - RJ-45 , 1 x display / video - VGA - 15 pin D-Sub (DB-15) , 2 x display / video - DisplayPort , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x storage - eSATA
- Security lock slot (cable lock sold separately), on/off switch, 0-Watt technology
- Power Device
- Power adapter
- Designed For
- Fujitsu CELSIUS Mobile H730, H730 Optimized for Adobe , Fujitsu LIFEBOOK E544, E734, E744, E754, T725, U745
