Your basket is empty
Fujitsu Port Replicator & AC Adapter (no UK Mains Cable)
Quicklinx: 9QCVWS00 Mfr#: S26391-F1137-L100
It is flexibility, expandability, desktop replacement, investment protection - to name just a few benefits of Fujitsu docking options. In the office or at home it takes just a second to attach your notebook to the port replicator and get connected to your external display, keyboard and mouse, for example. Your workplace is simple and tidy while you are ready to work with your notebook.
Fujitsu - port replicator
Port replicator
Power adapter 100 Watt
LIFEBOOK U772
Port replicator
4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - DVI-Digital , 1 x network - Ethernet 1000 - RJ-45 , 1 x docking / port replicator
On/off switch
Power adapter
Power Provided
100 Watt
Fujitsu LIFEBOOK U772
9QCV C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9QCV C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.73
9QCV C2G 5m Select High Speed HDMI with Ethernet In Stock £15.61
9QCV C2G 10m Select High Speed HDMI with Ethernet In Stock £29.98
9QCV C2G 15m Select High Speed HDMI with Ethernet In Stock £40.60
9QCV C2G Pro HDMI to VGA Converter In Stock £46.06
