Fujitsu P27-8 TS 27" 2560x1440 5ms VGA DVI HDMI DP LED IPS Monitor
Quicklinx: DLJCWS00 Mfr#: BDL:K1594V160-UK
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
£403.71 ex VAT
£484.45 inc VAT
If you're a pixel, color and performance-hungry professional, using demanding applications, the Fujitsu P27-8 TS Pro display is the perfect choice. The display provides outstanding picture performance thanks to advanced panel technology and multiple pixels. It also boasts unique and innovative features, such as Presence Sensor technology and USB support during standby.
Fujitsu P27-8 TS Pro - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
24 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, 2xDisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
61.3 cm x 22.7 cm x 39.6 cm
7.61 kg
United Kingdom
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, BSMI, GOST, cUL, EN 60950, SASO, CCC, RoHS, ISO 9241-307, WEEE, S Mark, KC, Directive 2004/108/EEC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Energy Class
Class A
36 kWh
24 W
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
48 - 76 Hz
Horizontal Refresh Rate
30 - 100 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
Eco-Mode, touch keys, Auto Brightness Control, ECO button, DisplayView, DICOM calibrated, 77% NTSC (CIE 1931) colour gamut, 100% sRGB colour gamut, Auto Pivot, built-in speakers
Matte black
61.3 cm x 22.7 cm x 39.6 cm - with stand
7.61 kg
Audio
Speakers
DisplayPort (DisplayPort 1.2 mode) , DisplayPort , HDMI , DVI , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DisplayPort cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
United Kingdom
Security Slot Type
Kensington security slot
36 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.2 Watt
Dimensions & Weight Details
With stand - width: 61.3 cm - depth: 22.7 cm - height: 39.6 cm - weight: 7.61 kg , Without stand - width: 61.3 cm - depth: 5.7 cm - height: 36.4 cm - weight: 3.02 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
Fujitsu P27-8 TS 27 Bundle deal on Fujitsu P27-8 TS 27" 2560x1440 5ms VGA DVI HDMI DP LED IPS Monitor
£502.88
Diagonal Size: 27in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Brand: Fujitsu
Price Range Ex VAT: 300 - 500
