The FUJITSU P24-8 WS Pro display provides outstanding picture performance thanks to cutting edge panel technology. It is the perfect choice for CAD and document management applications with request for 1,200 lines. It also boasts unique and innovative features such as the patent applied Presence Sensor technology and USB support during standby.
Minimized frame on three sides of the screen ensure future oriented, space-saving design. The gap between two panels is almost eliminated - only 6.7 mm border around the active picture area on top and the sides.
- Fujitsu P24-8 WS Pro - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 19 W
- Daisy Chaining
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB, 77% NTSC (CIE 1931)
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 53.2 cm x 22.7 cm x 38.9 cm
- 7 kg
- Localisation
- United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, S Mark, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 28 kWh
- Diagonal Size
- 24"
- Daisy Chaining
- Built-in Devices
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 5 ms
- Vertical Refresh Rate
- 48 - 76 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 6500K, 7500K
- OSD Languages
- Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- HDCP, Overdrive technology, touch keys, Auto Brightness Control, ECO button, DisplayView, DICOM calibrated, Low Blue Light Mode, built-in speakers, AutoPivot sensor
- Matte black
- 53.2 cm x 22.7 cm x 38.9 cm - with stand
- 7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1.5 Watt
- DisplayPort 1.2 , DVI-D (HDCP) , 4 x USB 3.1 Gen 1 downstream , USB 3.1 Gen 1 upstream , Audio line-out , DisplayPort output , HDMI
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), cable guide, "Always On" USB port, 24x7 continuous operation
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Input Voltage
- 19 W
- Power Consumption (Typical)
- 14.4 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.2 Watt
- Dimensions & Weight Details
- With stand - width: 53.2 cm - depth: 22.7 cm - height: 38.9 cm - weight: 7 kg , Without stand - width: 53.2 cm - depth: 5.6 cm - height: 35 cm - weight: 3.8 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - pick-up and return
- 5 °C
- 35 °C
