Fujitsu P24-8 WS Pro 24.1" 1920x1200 5ms VGA DVI HDMI DP LED Monitor
Quicklinx: D0BLWS00 Mfr#: BDL:K1595V160-UK
The FUJITSU P24-8 WS Pro display provides outstanding picture performance thanks to cutting edge panel technology. It is the perfect choice for CAD and document management applications with request for 1,200 lines. It also boasts unique and innovative features such as the patent applied Presence Sensor technology and USB support during standby.
Minimized frame on three sides of the screen ensure future oriented, space-saving design. The gap between two panels is almost eliminated - only 6.7 mm border around the active picture area on top and the sides.
Fujitsu P24-8 WS Pro - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Daisy Chaining
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
100% sRGB, 77% NTSC (CIE 1931)
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Matte black
53.2 cm x 22.7 cm x 38.9 cm
7 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, S Mark, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
3-year warranty
Display Type
Energy Class
Class A+
28 kWh
Diagonal Size
24"
Daisy Chaining
Built-in Devices
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
5 ms
Vertical Refresh Rate
48 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
HDCP, Overdrive technology, touch keys, Auto Brightness Control, ECO button, DisplayView, DICOM calibrated, Low Blue Light Mode, built-in speakers, AutoPivot sensor
Matte black
53.2 cm x 22.7 cm x 38.9 cm - with stand
7 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
DisplayPort 1.2 , DVI-D (HDCP) , 4 x USB 3.1 Gen 1 downstream , USB 3.1 Gen 1 upstream , Audio line-out , DisplayPort output , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable guide, "Always On" USB port, 24x7 continuous operation
Stand
1 x DisplayPort cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
United Kingdom
Security Slot Type
Kensington security slot
Input Voltage
19 W
Power Consumption (Typical)
14.4 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.2 Watt
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 22.7 cm - height: 38.9 cm - weight: 7 kg , Without stand - width: 53.2 cm - depth: 5.6 cm - height: 35 cm - weight: 3.8 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
