Fujitsu P24-8 TE Pro display is the perfect choice for demanding and tidy workplaces. Besides thin bezels and cable guide it also boasts unique features, such as USB support in standby and the presence sensor to detect the user's absence. With the call indicator you are prepared for modern applications.
- Fujitsu P24-8 TE Pro - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class A
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 19 W
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Marble grey
- 55.3 cm x 22.94 cm x 34.7 cm
- 5.6 kg
- Localisation
- United Kingdom
- Environmental Standards
- TCO Certified Displays 7, ENERGY STAR Qualified
- FCC Class B certified, TUV GS, BSMI, EN 60950, SASO, CCC, RoHS, ISO 9241-307, WEEE, S Mark, cTUVus, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 32 kWh
- 19 W
- Diagonal Size
- 23.8"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 6500K, 7500K
- OSD Languages
- Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- HDCP, Eco-Mode, Auto Brightness Control, ECO button, DisplayView, DICOM calibrated, Low Blue Light Mode, Auto Pivot, built-in speakers
- Marble grey
- 55.3 cm x 22.94 cm x 34.7 cm - with stand
- 5.6 kg
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- DisplayPort , VGA , DVI-D , 3 x USB 3.1 Gen 1 downstream , USB 3.1 Gen 1 upstream , Audio line-in , Audio line-out
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m , 1 x audio cable - 1.8 m , 1 x DVI cable - 1.8 m
- MTBF
- 70,000 hour(s)
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 20 Watt
- Power Consumption Stand by
- 0.27 Watt
- Power Consumption Sleep
- 0.15 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 55.3 cm - depth: 22.94 cm - height: 34.7 cm - weight: 5.6 kg , Without stand - width: 55.3 cm - depth: 6.35 cm - height: 33.02 cm - weight: 3.5 kg
- ENERGY STAR Certified
- TCO Certified
- Limited warranty - 3 years - pick-up and return
- 5 °C
- 35 °C
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£305.60
