Fujitsu P24-8 TE 23.8" 1920x1080 5ms VGA DVI DP LED IPS Monitor
Quicklinx: DLJBWS00 Mfr#: BDL:K1593V140-UK
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£206.43 ex VAT
£247.71 inc VAT
Fujitsu P24-8 TE Pro display is the perfect choice for demanding and tidy workplaces. Besides thin bezels and cable guide it also boasts unique features, such as USB support in standby and the presence sensor to detect the user's absence. With the call indicator you are prepared for modern applications.
Fujitsu P24-8 TE Pro - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
19 W
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Marble grey
55.3 cm x 22.94 cm x 34.7 cm
5.6 kg
United Kingdom
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
FCC Class B certified, TUV GS, BSMI, EN 60950, SASO, CCC, RoHS, ISO 9241-307, WEEE, S Mark, cTUVus, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Energy Class
Class A
32 kWh
19 W
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
HDCP, Eco-Mode, Auto Brightness Control, ECO button, DisplayView, DICOM calibrated, Low Blue Light Mode, Auto Pivot, built-in speakers
Marble grey
55.3 cm x 22.94 cm x 34.7 cm - with stand
5.6 kg
Audio
Speakers
Output Power / Channel
2 Watt
DisplayPort , VGA , DVI-D , 3 x USB 3.1 Gen 1 downstream , USB 3.1 Gen 1 upstream , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DisplayPort cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m , 1 x audio cable - 1.8 m , 1 x DVI cable - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
Security Slot Type
Kensington security slot
20 Watt
Power Consumption Stand by
0.27 Watt
Power Consumption Sleep
0.15 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 55.3 cm - depth: 22.94 cm - height: 34.7 cm - weight: 5.6 kg , Without stand - width: 55.3 cm - depth: 6.35 cm - height: 33.02 cm - weight: 3.5 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
Fujitsu P24-8 TE 23.8 Bundle deal on Fujitsu P24-8 TE 23.8" 1920x1080 5ms VGA DVI DP LED IPS Monitor
£305.60
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Fujitsu
Price Range Ex VAT: 150 - 300
