With the functionality of many devices, yet the simplicity of one, the N7100 network scanner contains the qualities organizations of all sizes desire to improve business processes.
A large size screen with integrated on-screen keyboard and PC functions are equipped in this compact network scanner. It can be used in the office or a teller window where space is limited. The user can perform scanning, data saving and transmission without the need to operate from a computer.
Scanning speed is consistent at 25 pages per minute (ppm) even when scanning full A4 color, double-sided, at 300dpi. N7100 is equipped with accurate and stable feeding mechanisms that support scanning from thin paper to thick paper, and plastic cards. Plastic ID cards and application forms can be scanned together easily at a teller window of banks or hospitals.
In order for the user not to feel any stress, the image processing after scanning is quick thanks to the enhanced CPU/memory. The time from the start of scanning to the finish including image processing (when the preview of the last scanned page appears) is 50% shorter than the previous model. For regular scanning routines, only one touch of the scan button is necessary which greatly improves the productivity.
The N7100 achieves high security on the premise that it is shared by multiple users. Not only verification before scanning, but also the encryption for paused scans and data deletion after scanning are performed automatically. Users can use the network scanner with peace of mind.
Administrators can customize the touch panel job menu and scan settings of N7100 to suit the work of a specific user or user group registered to the scanner. The user's application can be integrated to the scanner as add-in software using the exclusive SDK (for Windows). N7100 comes with an open USB port to connect a keyboard or other USB devices (except USB memory). N7100 can be customized to be a terminal exclusively for your operation.
The scanner driver PaperStream IP which supports TWAIN saves the hassle in fine adjusting the document for OCR processes. It automatically converts the images into exceptionally clean images, accelerating OCR even when scanning wrinkled/soiled document or documents with a background.
Advanced automated functions ensure N7100 digitizes your documents with remarkable precision and efficiency. Produce beautiful scans quickly with barely the need to lift a finger.
- Fujitsu Network Scanner N7100 - document scanner - desktop - Gigabit LAN
- Document scanner - desktop
- Interface Type
- Gigabit LAN
- Scan Element Type
- Dual CIS
- Light Source
- RGB LED array
- Additional Functions
- Email, fax, scan to print, scan to network share, scan to FTP
- Max Supported Document Size
- 216 x 355.6 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 25 ppm (mono) / 25 ppm (colour)
- Max Document Size
- 216 mm x 355.6 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card, envelope, post card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 400 scans per day
- Power
- AC 120/230 V
- 30 cm x 23.2 cm x 17.2 cm
- 6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- Gigabit LAN
- 216 x 355.6 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Element Type
- Dual CIS
- Bulb / Light Source Type
- RGB LED array
- Max Document Scan Speed B/W
- 25 ppm
- Max Document Scan Speed Colour
- 25 ppm
- Duty Cycle
- 400 scans per day
- Scanner Speed Details
- 25 ppm - portrait - A4 - 200 dpi , 25 ppm - portrait - A4 - 300 dpi , 50 ipm - portrait - A4 - 200 dpi , 50 ipm - portrait - A4 - 300 dpi
- Scanner Features
- 8.4" touch screen TFT display, automatic page size detection, Ultrasonic Multi Feed Detection
Media Handling
- Max Document Size
- 216 mm x 355.6 mm
- Supported Document Size Details
- Long document - up to 216 x 3048 mm
- Automatic
- 50 sheets
- Gigabit LAN
- RoHS 2011/65/EU
- ENERGY STAR Certified
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 38 Watt
- Power Consumption Stand by
- 1 Watt
- Power Consumption Sleep
- 2 Watt
- 30 cm
- 23.2 cm
- 17.2 cm
- 6 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.20 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £11.64 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.15 |
Fujitsu Extends Warranty From 1 Year to 3 Year For Network - Inc Replacement and Shipping | In Stock | £240.21 |
Fujitsu Extends Warranty to 3 Year for Network Scanners - 8hrs On-Site 8hrs Fix | In Stock | £453.56 |
