The FUJITSU notebook LIFEBOOK U745 is a slim and light Ultrabook for professionals supporting optimum mobility for business trips and ergonomics in the office. It is with a 35.6 cm (14-inch) anti-glare display with touch panel and backlit keyboard offers you mobile comfort. Moreover, an embedded palm vein sensor option guarantees ultimate protection of your data. The common port replicator with the LIFEBOOK E family facilitates workplace sharing, the VGA port allows you to present on demand.
Elegance in combination with ergonomics
U745 is a slim and lightweight notebook, HD+ anti-glare display with touch panel, magnesium housing with aluminum palm rest. -
Optimum mobility and workplace convenience in one
Ultrabook features VGA port, display port, common port replicator with LIFEBOOK E family, Anytime USB Charge to charge phones, media devices, even when the system is turned off, backlit keyboard. -
Ultimate connectivity
Ultimate connectivity is provided thanks to pull-out LAN connector, embedded 4G/LTE or 3G/UMTS, WLAN and Bluetooth. -
Easy upgradeability
Door serves to exchange the battery, memory and internal storage.
- Fujitsu LIFEBOOK U745 - 14" - Core i5 5200U - 8 GB RAM - 128 GB SSD
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro 64-bit + Windows 10 Pro Licence
- Processor
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz (2.7 GHz) / 3 MB Cache
- Memory
- 8 GB DDR3L (1 x 4 GB + 4 GB (soldered))
- Storage
- 128 GB SSD
- Display
- 14" LED backlight 1600 x 900 / HD+
- Graphics
- Intel HD Graphics 5500
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 9.5 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 33.26 cm x 23.4 cm x 1.9 cm
- 1.55 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 2 years - pick-up and return
- Product Type
- Ultrabook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro Licence
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 4 GB + 4 GB (soldered))
- Max RAM Supported
- 12 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 128 GB SSD SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Stereo speakers, stereo microphone
- Codec
- Realtek ALC3233
Input
- Keyboard, touchpad
- ECO button, spill-resistant, status led
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Intel Wireless Display (WiDi), Wake-on-LAN (WOL), 2x UMTS/LTE aerials
Wireless Broadband (WWAN)
- Generation
- 3G/4G upgradable
- Technology
- 4-cell lithium polymer
- Capacity
- 45 Wh
- Run Time
- Up to 9.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 90 Watt, 19 V, 4.74 A
Connections & Expansion
- Audio line-out , Audio line-in , 3 x USB 3.0 , VGA , DisplayPort , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- LifeBook Application Panel, Adobe Reader, Fujitsu Shock Sensor Utility, Fujitsu Display Manager, Power Saving Utility, Fujitsu Recovery, Plugfree Network, Microsoft Office 2013 (Trial), DeskView Client, DeskView Instant BIOS Management, DeskView Integration for Symantec Management Platform, McAfee Multi Access (60 days trial), Workplace Protect, Windows 7 Professional 64-bit / Windows 10 Pro 64-bit Twin-Pack recovery DVD
- Dockable
- Security
- Administrator password, system password, hard drive password, wake on LAN, 1 USB 3.0 with Anytime USB Charge, Preboot Execution Environment (PXE) support
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- WHQL, CB, RoHS, ISO 9241-307, WEEE
- Localization
- 1.55 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 85%
