Fujitsu Lifebook T937 Intel Core i7-7600U 16GB 512GB SSD 13.3" Touchscreen Windows 10 Pro 64-bit
Quicklinx: CYLYWS00 Mfr#: VFY:T9370M47BPGB
  • Core i7
  • IEEE 802.11n
The FUJITSU tablet LIFEBOOK T937 is a versatile 2-in-1 Ultrabook for demanding professionals with dynamic work styles. Its ultra-thin, durable magnesium housing, and super lightweight design enable you to travel in comfort. With a simple flip of the super crisp, rotatable 13.3-inch FHD display with pen and touch support you can switch to tablet mode. The backlit keyboard layout, enterprise-grade security features, pull-out LAN connector and embedded 4G/LTE let you work securely wherever you are.
Fujitsu LIFEBOOK T937 - 13.3" - Intel Core i7 - 7600U - vPro - 16 GB RAM - 512 GB SSD - UK
Ultrabook - convertible
Operating System
Win 10 Pro 64-bit
Platform Technology
Intel vPro Platform
Intel Core i7 (7th Gen) - 7600U / 2.8 GHz / 4 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
512 GB SSD - SED, TCG Opal Encryption, EraseDisk
Display
13.3" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
Digitizer, digital pen
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell - up to 10 hour(s)
Ambient light sensor, digital compass, magnetometer, gyro sensor, 3-axis accelerometer
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader, palm vein sensor
31.8 cm x 22.4 cm x 1.98 cm
1.3 kg
Region: United Kingdom
Environmental Standards
- EPEAT Climate+
Limited warranty - 2 years - pick-up and return
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7600U / 2.8 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Platform Technology
Intel vPro Platform
RAM
16 GB (1 x 16 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
Slots Qty
1
Empty Slots
0
Storage
Main Storage
512 GB SSD M.2 SATA 6Gb/s - Self-Encrypting Drive, TCG Opal Encryption, EraseDisk
Display
13.3"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
330 cd/m²
Anti-glare, magnesium lid
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Camera Features
LED indicator
Sound
Stereo speakers, two microphones
Codec
Realtek ALC255
Input
Keyboard, digitizer, touchpad, digital pen
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Dual Digitizer
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
DMI, CIM
Wake-on-LAN (WOL)
4-cell lithium polymer
50 Wh
Run Time
Up to 10 hour(s)
AC Adapter
Input
Output
65 Watt, 19 V, 3.42 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.1 Gen 2 , USB 3.1 Gen 2 (Anytime USB Charge) , USB-C , VGA , HDMI , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Fujitsu Shock Sensor Utility, Fujitsu Display Manager, CyberLink Youcam, Power Saving Utility, Plugfree Network, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, Workplace Protect, Fujitsu DeskUpdate, Windows 10 Pro 64-bit recovery DVD
Integrated Options
Dockable
Security
Administrator password, system password, hard drive password, RapidCharge, Fujitsu EraseDisk, BIOS Absolute Persistence, Preboot Execution Environment (PXE) support
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
1.3 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
5 °C
35 °C
20 - 80%
