The FUJITSU tablet LIFEBOOK T937 is a versatile 2-in-1 Ultrabook for demanding professionals with dynamic work styles. Its ultra-thin, durable magnesium housing, and super lightweight design enable you to travel in comfort. With a simple flip of the super crisp, rotatable 13.3-inch FHD display with pen and touch support you can switch to tablet mode. The backlit keyboard layout, enterprise-grade security features, pull-out LAN connector and embedded 4G/LTE let you work securely wherever you are.
- Fujitsu LIFEBOOK T937 - 13.3" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Ultrabook - convertible
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - SED, TCG Opal Encryption
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Input Device
- Digitizer, digital pen
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 4-cell - up to 10 hour(s)
- Ambient light sensor, digital compass, magnetometer, gyro sensor, 3-axis accelerometer
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader, palm vein sensor
- 31.8 cm x 22.4 cm x 1.98 cm
- 1.3 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 2 years - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s - Self-Encrypting Drive, TCG Opal Encryption
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 330 cd/m²
- Anti-glare, magnesium lid
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Camera Features
- LED indicator
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC255
Input
- Keyboard, digitizer, touchpad, digital pen
- Keyboard Layout
- UK
- Multi-gesture touch pad, Dual Digitizer
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Remote Management Protocol
- DMI, CIM
- Wake-on-LAN (WOL)
- Technology
- 4-cell lithium polymer
- Capacity
- 50 Wh
- Run Time
- Up to 10 hour(s)
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.1 Gen 1 , USB 3.1 Gen 1 (Anytime USB Charge) , USB-C , VGA , HDMI , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Adobe Reader, Fujitsu Shock Sensor Utility, Fujitsu Display Manager, CyberLink Youcam, Power Saving Utility, Plugfree Network, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, Workplace Protect, Fujitsu DeskUpdate, Windows 10 Pro 64-bit recovery DVD
- Integrated Options
- Dockable
- Security
- Administrator password, system password, hard drive password, RapidCharge, BIOS Absolute Persistence, Preboot Execution Environment (PXE) support
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- 5 °C
- 35 °C
- 20 - 80%
