Its ultra-thin, durable aluminum housing with magnesium lid and its light weight let you to travel in comfort. With a simple flip of the super crisp, rotatable 13.3ยด display with pen and touch support you can switch to tablet mode. The backlit keyboard, enterprise-grade security features, pull-out LAN connector and embedded 4G/LTE let you work securely wherever you are.
Tablet and Ultrabook in one
Bidirectional rotatable 13.3" display with dual digitizer allows audit-proof pen and touch input, or with the keyboard. Give your work a personal touch and enjoy the benefits of precise handwriting recognition and multiple-touch. -
Ultimate mobility
Be available anytime anywhere with wireless connectivity and additional features that ease your life. -
Highest security
SmartCard reader, fingerprint sensor, OPAL encrypted drives and Trusted Platform Module (TPM). Protect your company data against unauthorized third-party access. -
Ergonomic working
Super high resolution display and backlit keyboard maximize your productivity with ultimate convenience and comfort features for business users.
- Fujitsu LIFEBOOK T936 - 13.3" - Intel Core i7 - 6600U - vPro - 8 GB RAM - 512 GB SSD - 4G LTE
- Product Type
- Ultrabook - convertible
- Operating System
- Win 10 Pro 64-bit
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (6th Gen) - 6600U / 2.6 GHz, up to 3.4 GHz / 4 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 512 GB SSD - FDE, TCG Opal Encryption
- Display
- 13.3" LED backlight touchscreen 2560 x 1440 / WQHD
- Graphics
- Intel HD Graphics 520
- Input Device
- Digitizer, digital pen
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- 4-cell - up to 10 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 32.1 cm x 23.5 cm x 1.93 cm
- 1.6 kg
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 2 years - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6600U / 2.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD SATA 6Gb/s - Full Disk Encryption (FDE), TCG Opal Encryption
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 350 cd/m²
- Glare, WideView, magnesium lid, IGZO technology
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1920 x 1080
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- Codec
- Realtek ALC283
Input
- Keyboard, digitizer, touchpad, digital pen
- Multi-gesture touch pad, Dual Digitizer
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Wake-on-LAN (WOL), 2x UMTS/LTE aerials
- Generation
- 4G
- Technology
- LTE
- Controller
- Sierra Wireless AirPrime EM7305
- Max Transfer Rate
- 100 Mbps
- Technology
- 4-cell lithium polymer
- Capacity
- 45 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , HDMI , LAN , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Adobe Reader, Microsoft Office (Trial), Fujitsu Security Application Panel, Fujitsu Shock Sensor Utility, Fujitsu Display Manager, CyberLink Youcam, Power Saving Utility, Plugfree Network, Microsoft Office 2013 (Trial), McAfee Multi Access (60 days trial), Fujitsu DeskUpdate, Absolute Computrace Mobile
- Integrated Options
- Dockable
- Security
- Administrator password, system password, hard drive password, digital compass, Accelerometer, capacitive touch screen, gyroscope, 1 USB 3.0 with Anytime USB Charge, Preboot Execution Environment (PXE) support
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- GOST, EN 60950, RoHS, WEEE
- 1.6 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 85% (non-condensing)
