The FUJITSU Notebook LIFEBOOK S936 is a touch-enabled notebook for frequent travelers with highest demands. Lightweight from 1.19 kg (2.62 lbs), with a battery runtime up to 24 hours, a crystal clear 33.8 cm (13.3-inch) WQHD anti-glare display option and unique palm vein sensor option empower you to work with confidence wherever you are.
Flexible functionality with modular bay
Extend battery runtime up to 24 hours with a second battery option and primary battery, further options are a second hard disk drive, Blu-ray Disc or DVD Super Multi drive. -
Superb mobility
Exceptionally lightweight starting from 1.19 kg (2.62 lbs), with a sturdy magnesium housing and aluminum palm rest, optional 4G/LTE connectivity and NFC. -
Ultimate security
Embedded palm vein sensor or fingerprint sensor option, integrated SmartCard reader, encrypted disk, TPM option. -
Great ergonomics
A crystal clear resolution WQHD 33.8 cm (13.3-inch) display with anti-glare, non-touch or glare, touch option, backlit keyboard.
- Fujitsu LIFEBOOK S936 - 13.3" - Intel Core i7 - 6600U - 12 GB RAM - 512 GB SSD - 4G LTE
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6600U / 2.6 GHz, up to 3.4 GHz / 4 MB Cache
- Memory
- 12 GB DDR4 (1 x 8 GB + 4 GB (soldered))
- Storage
- 512 GB SSD - TCG Opal Encryption
- Display
- 13.3" LED backlight touchscreen 2560 x 1440 / WQHD
- Graphics
- Intel HD Graphics 520
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Dockable
- Security
- Smart card reader
- Black/silver
- 31.6 cm x 21.4 cm x 2.62 cm
- 1.32 kg
- Manufacturer Selling Program
- Fujitsu Premium Selection
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6600U / 2.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 12 GB (1 x 8 GB + 4 GB (soldered))
- Max RAM Supported
- 20 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 SATA 6Gb/s - TCG Opal Encryption
Display
- 13.3" - IGZO
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 330 cd/m²
- Glare, magnesium lid, Intel Wireless Display (WiDi)
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Stereo speakers, stereo microphone
- Codec
- Realtek ALC283
- High Definition Audio
Input
- Keyboard, touchpad
- ECO button, multi-gesture touch pad, status led
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Intel Wireless Display (WiDi), Wake-on-LAN (WOL)
- Generation
- 4G
- Technology
- LTE
- Controller
- Sierra Wireless AirPrime EM7305
- Max Transfer Rate
- 100 Mbps
- Technology
- Lithium Ion
- Installed Qty
- 1
- Max Supported Qty
- 2
Connections & Expansion
- Expansion Bays
- 1 x Modular Bay
- Interfaces Details
- 3 x USB 3.0 , HDMI , Headphone/microphone combo jack , VGA , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- LifeBook Application Panel, Adobe Reader, Fujitsu Shock Sensor Utility, Fujitsu Display Manager, Power Saving Utility, Plugfree Network, Microsoft Office 2013 (Trial), McAfee Multi Access (60 days trial), Fujitsu DeskUpdate
- Black/silver
- Dockable
- Security
- Smart card reader
- Administrator password, system password, hard drive password, 1 USB 3.0 with Anytime USB Charge, Preboot Execution Environment (PXE) support
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- WHQL, CB, RoHS, ISO 9241-307, WEEE
- 1.32 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 85%
