The FUJITSU Tablet LIFEBOOK P727 is an ultra-light, portable 2 in 1 device with a day-long battery that enables an agile multi-mode working style. The device can handle demanding design- and illustration-based applications with ease using Intel processors.
- Fujitsu LIFEBOOK P727 - 12.5" - Intel Core i5 - 7200U - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 128 GB SSD - SED, TCG Opal Encryption
- Display
- 12.5" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Input Device
- Digitizer, Tablet Pen
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 10 hours
- Ambient light sensor, digital compass, magnetometer, gyro sensor, 3-axis accelerometer
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 29.9 cm x 20.9 cm x 1.879 cm
- 1.2 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 2 years - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 128 GB SSD M.2 SATA 6Gb/s - Self-Encrypting Drive, TCG Opal Encryption
Display
- 12.5"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare, WideView, magnesium lid
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Camera Features
- LED indicator
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC255
Input
- Keyboard, digitizer, touchpad, Tablet Pen
- Keyboard Layout
- UK
- Multi-gesture touch pad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Remote Management Protocol
- DMI, CIM
- Wake-on-LAN (WOL)
- Technology
- 3-cell lithium polymer
- Installed Qty
- 1
- Capacity
- 45 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (Anytime USB Charge) , USB-C , VGA , HDMI , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Adobe Reader, Fujitsu Shock Sensor Utility, Fujitsu Display Manager, CyberLink Youcam, Power Saving Utility, Plugfree Network, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, Workplace Protect, Fujitsu DeskUpdate, Windows 10 Pro 64-bit recovery DVD
- Integrated Options
- Dockable
- Security
- Administrator password, system password, hard drive password, BIOS Absolute Persistence, Preboot Execution Environment (PXE) support
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, WACOM Digitiser pen
- Localization
- 1.2 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- 5 °C
- 35 °C
- 20 - 80%
