Product
Brand
Fujitsu HD SATA 6G 1TB 7.2K No Hot Plug 3.5" BC
Quicklinx: 9DHGWS00 Mfr#: S26361-F3671-L100
The Fujitsu Hard Disk Drive is the ultimate portable Hard Disk Drive and backup system. Its sleek, slim, self-powered design makes it an ideal traveling companion so you can backup or reinstall data wherever you are. The device’s high capacity also makes it an excellent storage solution for your home computer. With storage capacities the Fujitsu Hard Disk Drive adds extra capacity to your system and is perfect for storing photos, music and video files.
Fujitsu Business Critical - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
PRIMERGY TX100 S3p, TX1310 M1, TX1320 M1 (3.5")
1 TB
3.5"
SATA 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Fujitsu PRIMERGY TX100 S3p, TX1310 M1, TX1320 M1 (3.5")
