Fujitsu Futro S920 AMD GX-424CC 4GB 16GB Windows Embedded Standard 7
Quicklinx: CZ7CWS00 Mfr#: VFY:S0920P70AOGB
Processor Type: GX-424CC
Operating System: Microsoft Windows Embedded Standard 7
Installed Memory: 4GB
Hard Drive Capacity: 16GB
Storage Type: Flash
£489.66 ex VAT
£587.59 inc VAT
The individually configurable Fujitsu FUTRO S920 has all the flexibility you need to optimize secure server-based computing and desktop virtualization. This simple, reliable yet powerful front-end device is easy to integrate and manage. It also offers expansion slots and unique connectivity options to maximize user convenience. Plus, its long lifecycle helps you minimize TCO.
  • Green technology
    Your company's contribution to environmental protection. A modern, environmentally conscious product concept - from development to recycling.
  • Relaxed working
    Quiet system for a pleasant working environment. Flash memory and passive cooling concept.
  • Energy efficiency
    Saves energy and reduces CO2 emissions. Integrated system concept with power-saving components.
  • Manageability
    Easy administration while reducing total cost of ownership. Outstanding manageability solution.
Fujitsu FUTRO S920 - DTS - GX-424CC 2.4 GHz - 4 GB - 16 GB - UK layout
Thin client - desktop slimline
Region: United Kingdom
1 x AMD GX-424CC 2.4 GHz (Quad-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
4 GB DDR3 SDRAM - PC3-12800
Storage Controller
SATA
Hard Drive
Flash 16 GB - mSATA
Optical Storage
No optical drive
Graphics Controller
AMD FirePro W2100 / AMD Radeon R5 Shared Video Memory (UMA)
Video Memory
2 GB
GigE
OS Provided
5.2 cm x 19.5 cm x 25.1 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 2 years - carry-in
Thin client
Product Form Factor
Desktop slimline
Processor / Chipset
CPU
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Configuration Features
1 x 4 GB
Hard Drive
Flash - mSATA
16 GB
Multi-level cell (MLC)
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Memory
2 GB
Max Allocated RAM Size
2 GB
Video Interfaces
VGA, DVI, DisplayPort
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
DHCP support
Slots
1 x audio line-in , 1 x audio line-out , 1 x headphones (1 in front) , 1 x audio line-in/microphone (1 in front) , 5 x USB 2.0 , 2 x USB 3.1 Gen 1 , 1 x DisplayPort , 1 x DVI-I , 2 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet)
Vertical stand, PCI Express riser card
DVI-VGA adapter
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion switch
Power adapter
Nominal Voltage
Power Provided
65 Watt
Operating System / Software
OS Provided
Software
Adobe Flash Player, Microsoft .NET Framework 2.0, Microsoft .NET Framework 3.5, Microsoft .NET Framework 3.0, Microsoft Windows Media Player 12, File Based Write Filter, Enhanced Write Filter, Microsoft .NET Framework 4, Microsoft Internet Explorer 11, Microsoft .NET Framework 4.5, SCOUT Agent, Citrix Receiver 4.2.1, Microsoft Windows Embedded Standard 7 recovery DVD, VMware Horizon View Client 3.4.0, Microsoft RDP Client Protocol 8.1, Visual C++ Redistributable
ENERGY STAR Certified
ENERGY STAR Version
6.1
Dimensions & Weight Details
5.2 cm - 19.5 cm - 25.1 cm - without stand , 9.7 cm - 19.5 cm - 26.7 cm - with stand
5.2 cm
19.5 cm
25.1 cm
1.3 kg
10 °C
35 °C
5 - 85%
Fujitsu Futro S920 AMD GX-424CC 4GB 16GB Windows Embedded Standard 7 Bundle deal on Fujitsu Futro S920 AMD GX-424CC 4GB 16GB Windows Embedded Standard 7
£676.12
saving £8.33
£581.20
Storage Type: Flash
Type: Thin client
Case Style: Desktop slimline
Display: no
Optical Storage: None
Brand: Fujitsu
Price Range Ex VAT: 300 - 500
