Fujitsu Futro S920 AMD GX-424CC 4GB 16GB Windows Embedded Standard 7
Quicklinx: CZ79WS00 Mfr#: VFY:S0920P701BGB
The individually configurable Fujitsu FUTRO S920 has all the flexibility you need to optimize secure server-based computing and desktop virtualization. This simple, reliable yet powerful front-end device is easy to integrate and manage. It also offers expansion slots and unique connectivity options to maximize user convenience. Plus, its long lifecycle helps you minimize TCO.
  • Green technology
    Your company's contribution to environmental protection. A modern, environmentally conscious product concept - from development to recycling.
  • Relaxed working
    Quiet system for a pleasant working environment. Flash memory and passive cooling concept.
  • Energy efficiency
    Saves energy and reduces CO2 emissions. Integrated system concept with power-saving components.
  • Manageability
    Easy administration while reducing total cost of ownership. Outstanding manageability solution.
Fujitsu FUTRO S920 - DTS - GX-424CC 2.4 GHz - 4 GB - flash 16 GB - UK
Thin client - desktop slimline
Region: United Kingdom
1 x AMD GX-424CC 2.4 GHz (Quad-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
4 GB DDR3 SDRAM - PC3-12800
Hard Drive
Flash 16 GB - mSATA
Optical Storage
No optical drive
Graphics Controller
AMD Radeon R5 Shared Video Memory (UMA)
GigE
Keyboard
OS Provided
Microsoft Windows Embedded Standard 7
Software Included
Recovery DVD
5.2 cm x 19.5 cm x 25.1 cm
1.3 kg
Limited warranty - 2 years - on-site
Thin client
Product Form Factor
Desktop slimline
Built-in Devices
Speaker
Processor / Chipset
CPU
AMD GX-424CC
Clock Speed
2.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Hard Drive
Flash - mSATA
1 x 16 GB
Multi-level cell (MLC)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
2 GB
Video Interfaces
VGA, DVI, DisplayPort
Max Monitors Supported
2
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
DHCP support
Slots
1 x audio line-in , 1 x audio line-out , 1 x headphones (1 in front) , 1 x audio line-in/microphone (1 in front) , 4 x USB 2.0 (4 rear) , 2 x USB 3.0 (2 in front) , 1 x DisplayPort , 1 x DVI-I , 2 x serial , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet)
Vertical stand
DVI-VGA adapter
Theft/Intrusion Protection
Power adapter
Power Provided
40 Watt
Operating System / Software
OS Provided
Software
Recovery DVD
Dimensions & Weight Details
9.7 cm - 19.5 cm - 26.7 cm - with stand
5.2 cm
19.5 cm
25.1 cm
1.3 kg
10 °C
35 °C
5 - 85%
