The Fujitsu FUTRO S520 is your versatile thin client for highly secure server-based computing and desktop virtualization. It reduces your TCO significantly compared to a standard PC through low hardware costs, high energy efficiency and minimal administration requirements. Its small footprint and low noise emissions contribute to a pleasant working environment. Finally, high product quality ensures a long lifecycle.
- Fujitsu FUTRO S520 - DTS - GX-210HA 1 GHz - 2 GB - flash 4 GB
- Thin client - desktop slimline - UEFI BIOS
- Processor
- 1 x AMD GX-210HA 1 GHz (Dual-Core)
- Cache Memory
- 1 MB
- Cache Per Processor
- 1 MB
- RAM
- 2 GB DDR3 SDRAM - PC3-12800
- Storage Controller
- SATA
- Hard Drive
- Flash 4 GB
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 8210E Shared Video Memory (UMA)
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- eLux RP
- 8.8 cm x 17.4 cm x 18.5 cm
- 850 g
- Limited warranty - 2 years - on-site
- Thin client
- Product Form Factor
- Desktop slimline
Processor / Chipset
- CPU
- AMD GX-210HA
- Clock Speed
- 1 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 1 MB
- 1 MB
RAM
- Installed Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Configuration Features
- 1 x 2 GB
Hard Drive
- Flash
- Capacity
- 4 GB
- Multi-level cell (MLC)
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 256 MB
- Video Interfaces
- VGA, DVI
Input Device
- Mouse, keyboard
Mouse
- Mouse Name
- Fujitsu M510
- Data Link Protocol
- DHCP support
- Slots
- Memory
- 1 x audio line-in , 1 x audio line-out , 1 x headphones (1 in front) , 1 x audio line-in/microphone (1 in front) , 2 x USB 2.0 , 2 x USB 3.0 , 1 x DVI-I , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet)
- Included Accessories
- Vertical stand
- Cables Included
- DVI-VGA adapter
- UEFI BIOS
- Theft/Intrusion Protection
- Power adapter
- Voltage Required
Operating System / Software
- OS Provided
- eLux RP
- 8.8 cm
- 17.4 cm
- 18.5 cm
- 850 g
- 10 °C
- 35 °C
- 5 - 85%
