Fujitsu fi-7480 Duplex Document Scanner
Quicklinx: C38LWS00 Mfr#: PA03710-B001
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 304.8 x 431.8 mm
Interface: USB 3.0
Compatibility: PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Hurry, only 2 left in stock!
£2,192.20 ex VAT
£2,630.64 inc VAT
The fi-7480 is easy to set up, use and maintain and comes bundled with a user friendly and intuitive scanner driver PaperStream IP along with batch scanning automation and enhancement software PaperStream Capture. A4 landscape scanning speeds in both color or black and white at up to 300 dpi is 80 pages per minute or 160 images per minute through the 100 page capacity ADF. The fi-7480 can scan a huge variety of material from plastic cards to booklets to even folded A1 in size.
The fi-7480 scanner comes with a unique paper protection function that is based on acoustic sensors; iSOP (Intelligent Sonic Paper Protection), iSOP reduces the risk of having documents damaged by sensing the audible noise of paper movements and stopping the feeding of sheets when an irregular noise is encountered.
The scanner additionally makes use of an ultrasonic sensor that accurately detects multifeed errors where two or more sheets are fed through the scanner at once plus intelligent multifeed function that is designed for documents that intentionally feature paper attachments of defined sizes or locations such as sticky notes or photos. The scanner can automatically recognize the location of the attachment and will then exclude that zone from triggering alert conditions.
Skew Reducer helps ensure straight paper feeding, should you be scanning mixed batches of differing thicknesses of documents then the "skew reducer" eliminates the risk of physical skew being carried over from one sheet in a mixed batch to the next ensuring that each document is captured with the utmost precision and simplicity. Multi-segmented pick rollers that rotate independently ensure that if a document goes through skewed then this will not affect the alignment of the next document.
Integrated within the operating panel a backlight enhanced LCD shows useful information such as current scanner settings, operating status and a paper counter, in addition the fi-7480 comes with Scanner Central Admin tools that includes functions that system administrators can use to manage the installation and operation of multiple scanners, monitor operation status and update drivers and software from one location. This ability dramatically reduces the cost and work that goes into setting up, operating and maintaining many scanners in an organization and also in expanding the scanner network to multiple locations.
The fi-7480 comes bundled with PaperStream IP, an integrated scanner driver and image enhancement module that is built on TWAIN/ISIS standards offering user friendly operability, intuitive high quality image creation and real time processing that will benefit post scan routines like OCR. PaperStream Capture enhances the document capture process from adjusting scanning settings to performing batch scanning, verifying data and releasing to directories, repositories or subsequent process routines. Users can complete data capture tasks easily with the extremely user-friendly graphical user interface (GUI). Moving scanned batches into a queue for later retrieval is possible as well.
  • Reliable, uninterrupted volume scanning
    The fi-7480 can efficiently scan a large amount of documents. The ADF paper chute (feeder) can accommodate many sheets and additional papers can be added while scanning. It also offers several functions to ensure reliable scanning.
  • Connect your business workflow
    The PaperStream IP scanner driver, which supports TWAIN/ISIS, avoids the inconvenience of fine adjustments to the settings for OCR processes. It automatically converts the images into exceptionally clean images, accelerating OCR even when scanning wrinkled or soiled documents, or documents with a background pattern. With an intuitive interface, PaperStream Capture effectively and efficiently allows you to feed information into your organization's workflow through various capture features during batch scanning.
Fujitsu fi-7480 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Scan Element Type
Dual CCD
Light Source
White LED array
Max Supported Document Size
304.8 x 431.8 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
160 ppm (mono) / 160 ppm (colour)
Max Document Size
304.8 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
AC 120/230 V
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
38 cm x 20.9 cm x 16.8 cm
7.6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0
304.8 x 431.8 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
160 ppm
Max Document Scan Speed Colour
160 ppm
Scanner Speed Details
80 ppm - landscape colour - A4 , 80 ppm - landscape greyscale - A4 , 80 ppm - landscape B&W - A4 , 160 ipm - duplex - landscape colour - A4 - 200 dpi , 160 ipm - duplex - landscape greyscale - A4 - 200 dpi , 160 ipm - duplex - landscape B&W - A4 - 200 dpi , 160 ipm - duplex - landscape colour - A4 - 300 dpi , 160 ipm - duplex - landscape greyscale - A4 - 300 dpi , 160 ipm - duplex - landscape B&W - A4 - 300 dpi , 65 ppm - portrait B&W - A4 , 65 ppm - portrait greyscale - A4 , 65 ppm - portrait colour - A4 , 130 ipm - portrait B&W - A4 - 200 dpi , 130 ipm - portrait greyscale - A4 - 200 dpi , 130 ipm - portrait colour - A4 - 200 dpi , 130 ipm - portrait B&W - A4 - 300 dpi , 130 ipm - portrait greyscale - A4 - 300 dpi , 130 ipm - portrait colour - A4 - 300 dpi
Scanner Features
Multi Color Dropout, Image Emphasis, Long Paper Mode, Dynamic Threshold, Error Diffusion, automatic colour detection, Dither, Advanced DTC, Multi-Image Output, built-in LCD screen, Ultrasonic Multi Feed Detection, Punch Hole Removal, Deskew, Blank Page Detection, edge cleanup
TWAIN, ISIS
Media Handling
Max Document Size
304.8 mm x 5588 mm
Automatic
100 sheets
USB 3.0 - Type B
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
AC 120/230 V
Power Consumption Operational (Standby)
43 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
1.4 Watt
Software Included
Drivers & Utilities, ScanSnap Manager, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
38 cm
20.9 cm
16.8 cm
7.6 kg
5 °C
35 °C
20 - 80% (non-condensing)
C38L Fujitsu Extends Warranty From 1 Year to 3 Year For Department Scanners- Inc Replacement and Shipping In Stock £143.23
C38L Fujitsu Extends Warranty to 3 Years On-Site Fix for Departmental Scanners - Onsite Within 8 Hours In Stock £434.17
Interface: USB 3.0
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: 1500+
