Fujitsu fi-7300NX Document Scanner
Quicklinx: DXZLWS00 Mfr#: PA03768-B001
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 355.6 mm
Interface: Gigabit LAN, USB 3.1 Gen 1
  • Windows 8.1 (32/64 bits)
£784.93 ex VAT
£941.91 inc VAT
The fi-7300NX is an Image Scanner that supports web systems and connects directly to client systems. Users can begin scanning from the scanner's touch screen or from various applications on smart devices to suit all business needs. Not only is direct data transfer to client-unique web systems possible with SDK use, but secure data transfer is also possible with strong data encryption. The fi-7300NX boasts a speed of 60 ppm/120 ipm (200/300 dpi) for scanning A4 portraits, loads up to 80 sheets at a time, and ensures utmost efficiency as the first standalone scanner in the world to support 5 GHz Wi-Fi. The 4.3" touch screen enables users to perform operations intuitively, like scanning and data checking, with thumbnail reviews of scans and the screen also displays messages or instructions with illustrations so that users can handle errors themselves.
Users can scan and save documents without any requirement for a local computer, they can simply login to the scanner using user authentication and select a job from their personalized job menus on the fi-7300NX's touch screen. Customized job menus ensure efficient and secure decentralized data entry is possible for each user.
The fi-7300NX supports NFC (Type-A and Type-B) authentication and user authentication with username and password input on the touch screen. It is also possible for different job menus to be assigned to each scanner, and avoid any authentication processes. With PaperStream NX Manager, users can scan from mobile or web applications opened up on smart devices or thin client terminals. Seamless integration into company systems enables use of a variety of devices for scanning operations. The user authentication function, job menu, and other scan settings are all centrally managed with PaperStream NX Manager and Scanner Central Admin. With the fi-7300NX's server software, there is no need for the conventional single client computer to scanner environment and the system administrator to stand by the scanner. This reduces the total burden of installation, expansion, operation, and management. Manage jobs and process images with PaperStream NX Manager. Monitor scanner operation with Scanner Central Admin.
When scanning with computers, the fi-7300NX can be used with PaperStream IP, a specialized scanner driver for Fujitsu image scanners, via Wi-Fi connection, wired network, and USB connection. Connection without need for the USB cable allows the scanner to be positioned wherever needed, to improve user productivity, reduce interruptions, and make more room for more frequently used equipment.
  • Seamless integration into client systems
    Scan from the scanner's touch screen without any operation of the PC. Simply authenticate your ID and select from displayed client-specific job profiles. Not only is efficient and secure decentralized data entry possible, but single units can also be shared within numerous clients. Unlike the typical scanner, the fi-7300NX is no longer tethered to the PC and can be placed wherever desired. Users can also scan from mobile or web applications opened up on smart devices or thin client terminals. Providing various scanning methods, the fi-7300NX enables use of a variety of devices for scanning operations to suit all client needs.
  • Easy to use for any client
    Perform operations and view error messages and instructions with user-friendly illustrations, all on the 4.3-inch touch screen. Assign fixed operations to each scanner with the fi-7300NX supporting a variety of authentication methods.
Fujitsu fi-7300NX - document scanner - desktop - Gigabit LAN, USB 3.1 Gen 1
Document scanner - desktop
Interface Type
Scan Element Type
Dual CCD
Light Source
White LED array
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
4000 scans per day
Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
30 cm x 20.2 cm x 17 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
216 x 355.6 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
4000 scans per day
Scanner Speed Details
60 ppm - portrait - A4 - 200 dpi , 60 ppm - portrait - A4 - 300 dpi , 120 ipm - duplex - colour - 200 dpi , 120 ipm - duplex - colour - 300 dpi , 120 ipm - duplex - greyscale - 200 dpi , 120 ipm - duplex - greyscale - 300 dpi , 120 ipm - duplex - black & white - 200 dpi , 120 ipm - duplex - black & white - 300 dpi
Scanner Features
Built-in LCD screen, Ultrasonic sensor, Intelligent Sonic Paper Protection (iSOP), 4.3" touch screen TFT display, NFC authentication
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 5588 mm
Automatic
80 sheets
USB 3.1 Gen 1 , Gigabit LAN
ADF paper chute
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
42 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
2.4 Watt
Software Included
ScanSnap Manager, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture, PaperStream NX Manager
30 cm
20.2 cm
17 cm
4.9 kg
5 °C
35 °C
20 - 80% (non-condensing)
Interface: USB 3.1 Gen 1
Brand: Fujitsu
Price Range Ex VAT: 750 - 1000
