The fi-7180 document scanner from Fujitsu is armed with a host of automated hardware and software based tools designed to make the job of scanning mixed batches of documents as seamless and hassle free as possible. Impressive scan speeds, industry leading paper protection mechanisms, status monitoring tools and bundled Fujitsu developed driver (PaperStream IP) and image enhancement software (PaperStream Capture) help ensure that the capture of your documents is done reliably and efficiently.
Fast and compact
The fi-7180 has been introduced to support increasingly diverse business related document capture routines at the desktop of individual knowledge workers or small workgroups. Simple, productivity-boosting operation virtually eliminates training requirements. -
Large volume hopper
Featuring a high capacity hopper tray, these scanners allow for loading document batches containing up to 80 sheets at a time - and allowing for the continuous feeding of additional documents whilst scanning. -
High-speed interface
USB 3.0 support ensures high-speed data transfer between scanner and computer. -
LCD status display and control panel
A liquid crystal display (LCD) is included in the operator panel to display useful information including current settings for scanning documents, the number of sheets scanned, and error status. Users know the scanner status in the blink of an eye and can easily select and initiate predefined scanning profiles. -
iSOP - intelligent Sonic Paper Protection
Building on and incorporating the market-proven paper protection mechanisms of previous fi-series scanners, the fi-7180 introduces an additional market innovation for safeguarding any paper documents. By listening to the audible sound of paper movements, intelligent Sonic Paper Protection automatically suspends paper feeding if an irregular noise is detected. This advanced Paper Protection feature reliably reduces the risk of damaging documents during scanning. -
Stable paper feeding with skew reduction
The fi-7180 is equipped with a "Skew Reducer" to maintain the straight alignment of paper feeding. Particularly valuable for mixed document batches containing small format documents or thin paper sheets, this function reduces the physical skew of documents throughout the paper path. Even the most untidy batches are given special treatment sheet-by-sheet, which ensures total coverage for every scan: no lost data on the edges or in the corners, no more rescans. -
Less effort for effective, efficient pre-scan processing
The fi-7180 brings industry leading mixed batch scanning capabilities to the desktop with a design that allows for a record breaking mixed batch feeding range from 27-413 g/m2, freeing the user from most paper weight related pre-sorting requirements. The fi-7180 makes use of an ultrasonic sensor that accurately detects errors where two or more sheets are fed through the scanner at once. Multifeed detection works reliably when scanning mixed batches of documents with different paper weights and sizes. When multifeed is detected, the user is instantly alerted and can continue capturing all relevant sheets and pages without losing relevant information.
- Fujitsu fi-7180 - document scanner - desktop - USB 3.0
- Document scanner - desktop
- Interface Type
- USB 3.0
- Scan Element Type
- Dual CCD
- Max Supported Document Size
- 216 x 355.6 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 80 ppm (mono) / 80 ppm (colour)
- Max Document Size
- 216 mm x 5588 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 80 sheets
- Duty Cycle
- 6000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Ubuntu 16.04, Microsoft Windows Server 2016 (64-bit)
- 30 cm x 17 cm x 16.3 cm
- 4.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 3.0
- 216 x 355.6 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Element Type
- Dual CCD
- Max Document Scan Speed B/W
- 80 ppm
- Max Document Scan Speed Colour
- 80 ppm
- Duty Cycle
- Scanner Speed Details
- 80 ppm - colour - 200 dpi , 80 ppm - colour - 300 dpi , 80 ppm - greyscale - 200 dpi , 80 ppm - greyscale - 300 dpi , 80 ppm - black & white - 200 dpi , 80 ppm - black & white - 300 dpi , 160 ipm - duplex - colour - 200 dpi , 160 ipm - duplex - colour - 300 dpi , 160 ipm - duplex - greyscale - 200 dpi , 160 ipm - duplex - greyscale - 300 dpi , 160 ipm - duplex - black & white - 200 dpi , 160 ipm - duplex - black & white - 300 dpi
- Scanner Features
- Built-in LCD screen
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 5588 mm
- Plain paper
- Automatic
- 80 sheets
- USB 3.0 - Type B
- RoHS
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 42 Watt (1.8 Watt)
- Software Included
- ScanSnap Manager, Scan to Microsoft SharePoint, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture, Error Recovery Guide
- OS Required
- 30 cm
- 17 cm
- 16.3 cm
- 4.2 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
